Speed much lower than estmated speed..
- Speed much lower than estmated speed..
Re: Speed much lower than estmated speed..
14-01-2013 11:55 PM
15-01-2013 11:22 AM
I've had a look over your connection and your sync speed is currently at 15Mb/s. If possible could you perform 2 more speed tests at http://speedtest.btwholesale.com and run further diagnostics on one of them once the test has completed?
Let me know when you've managed to do that, if you're unsure on anything please let me know.
Chris
15-01-2013 12:39 PM
I will do that now...
syncing at 15 mb
the engineer did a test with his handheld device at said i should get 78 megs inspte of the estimate being 34 mbps...
15-01-2013 12:51 PM
Download: 13.88 mbps
Upload: 1.34 mbps
Ping Latency : 43.13 ms
BTW PERFOMANCE TEST 2 plus Diagnostics [15/1/13 @12.43]
Download: 14.01 mbps
Upload: 1.35 mbps
Ping Latency : 36.75 ms
Further diagnostics:
1. Best Effort Test: -provides background information.
Download speedachieved during the test was - 14.01 Mbps
For your connection, the acceptable range of speeds is 16 Mbps-0 Mbps.
IP Profile for your line is - 14.74 Mbps
Upload speed achieved during the test was - 1.35Mbps
Additional Information:
This test was not conclusive and further testing is required.This might be useful for your Broadband Service Provider to investigate the fault.
If you wish to carry out further tests,please click on 'Continue' button.If not, please close the window using 'Exit' button and contact your ISP for further assistance with these results.
NB: Please find screenshot attached..
15-01-2013 2:41 PM
You'd need to login to your router, it needs to be set up using the username speedtest@speedtest_domain and password testing and then connect, then run BT speed test window and re-run the test. If this isn't loading please try accessing the site through the IP address: http://193.113.8.194/ as the DNS servers may not work.
Once you've tried that let me know your results of the speed test and also remember to change your details in your router back to your details.
15-01-2013 3:25 PM
15-01-2013 3:45 PM
15-01-2013 3:49 PM
15-01-2013 4:25 PM
I got connected to router with username and pw you provided..
Tried BTW performance test...
In several attempts I kept getting this screen:
Please wait while we test your service..
Current progress 0%
System is busy. Please try again later.
15-01-2013 5:14 PM
If you're unsure on anything just give me a nudge but I'll keep an eye over it anyway.
15-01-2013 5:21 PM
when i logged in using my original username i could run the BTW performance test and diagnostics.
After diagnostics i clicked on test further which popped up this screen...
Following on the instructions there as well your instructions I disconnected from abhijack and logged in with speedtest@speedtest_domain and clicked go on tha already undertaken test. Then it did the third part and gave the following result.
NB: attaching for more clarity...
15-01-2013 5:26 PM
TAP 3 results attached with above post reads like this...
Test Results:
Download speed : 14.09
IP profile: 14.87
2. Upstream test :
Upload speed : 0
IP profile : 20
Your service was found to be performing poorly.
Please raise a fault with your service provider, stating that the BT performance tester tool indicates poor service throughput performance after the third test.
16-01-2013 8:32 AM
thanks for your update on the fault/question i raised..
can you update about the tap 3 there as well please... i.e i could test 1 & 2 using my regular account and continued to test 3 with the test account. results are in above post...
My observations about the connection so far:
thumbs up:
1.download speed has been stable [sorry i hope i dont jinx it..] at 14 Mb +/- 0.5
2. wireless gives almost same speed as wired...
thumbs down:
1. speed is still less than 50% of the estimated speed at time of order [34 Mb] and less than 20% of the speed [78 Mb] which engineer said i could get based on his test from master socket.
16-01-2013 9:50 AM
Just waiting for the results from your further diagnosis on your line and we'll be in-touch.
16-01-2013 10:18 AM
Please check my above post with TAP3 test that didnt fail and gave a result...
[Is that not valid as I could only do part 1 & 2 using abhijack and TAP 3 with the test username?? .. Anyway thats how BTW tester instructs to do. Screenshot of instructions attached with previous post..]
Attaching screenshot again if you missed it...
