Speed much lower than estmated speed..
- Speed much lower than estmated speed..
Re: Speed much lower than estmated speed..
14-01-2013 8:39 PM
Ex-Broadband Service Manager
14-01-2013 8:45 PM
Quote from: Kelly plug directly into the openreach modem and test from there?
thanks kelly..
can i unplug red ethernet cable [currently connecting modem to router] from router and plug it to my laptop?
do i need to reboot modem again?
14-01-2013 8:57 PM
14-01-2013 9:09 PM
14-01-2013 9:12 PM
Quote from: Kelly but try it out.
i tried connecting modem directly to laptop using both yellow and red ethernet cables those came with the router.
There is no internet access when i did that. only local access.
I tried to connect the modem directly to a desktop as well . Same problem as above - Local access only..No internet..
Now I have reconnected modem to router.
Back on internet but speed remains horribly slow at 14 mbps.
14-01-2013 9:13 PM
14-01-2013 9:16 PM
jim:quote
14-01-2013 10:05 PM
Quote from: Kelly Got a laptop so you can plug directly into the openreach modem and test from there?
Quote from: Oldjim This is what you need to do http://community.plus.net/library/broadband/fibre-help-how-to-set-up-a-pppoe-dialler-in-vistawindows...
Thanks Kelly and Jim.
I followed the instructions step by step religiously as per the link Jim kindly gave.
I am getting error after step 7. i.e no connection made to internet on neither windows 7 or vista...
I am pasting the error on windows 7..
Sorry its a bit tiny. It says the modem [or other connecting device] has reported an error.. IS it a faulty modem???
I dont have screenshot of error on Vista . But it said
"internet connectivity was unsuccessful"
14-01-2013 10:15 PM
14-01-2013 10:17 PM
Definite yes...
14-01-2013 10:21 PM
Quote from: abhijack I am getting error after step 7. i.e no connection made to internet on neither windows 7 or vista...
It might be worth trying a factory reset of the modem, rather than just rebooting it.
But! I don't think you should do anything more to the modem today. The DLM might be getting excited by now and we don't want that to go banding you and complicating things even more.
14-01-2013 10:30 PM
14-01-2013 10:34 PM
What amazes me is the extremely different numbers:
Current line speed : 78 mbps
estimated line speed : 34 mbps
what i get now :14 mbps
so there is something grossly wrong.. looks like the modem from those tests to me... if so will openreach replace it?
14-01-2013 10:36 PM
14-01-2013 11:31 PM
Another point I noticed only now on the router...
Green lights for internet, broadband , ethernet and wifi are flashing intermittently.
Is that an issue?
