Speed keeps dropping
- Speed keeps dropping
Re: Speed keeps dropping
02-08-2011 11:17 AM
Looks like the disconnection has given you a better sync rate, it's now 17499 so that will give you a profile of 15000 if it stays the same. As the rise is only a small percentage it can take longer to increase, possibly up to 120 hours of being constantly connected.
Jojo
02-08-2011 2:50 PM
Fingers crossed though that it does help, again will keep an eye on it.
Should I continue to disconnect once a day or leave it as it is?
Cheers
02-08-2011 3:08 PM
Definitely don't disconnect, because your profile will not rise if you do.
Jojo
05-08-2011 11:32 PM
Still having huge issues with the uploading interfering with things.
Earlier I was trying to upload some files and it just wouldn't upload, it caused xbox to lag out and pages wouldn't load up.
Speed in general seems slow even though speed test is at 9.7.
So basically can not do anything when uploading if it lets me do upload at all, starting to drive me a bit mental now as I need to upload things fairly often. I know I could avoid doing anything else while uploading but I shouldn't have to really.
Link Information
Uptime: 3 days, 17:40:08
DSL Type: G.992.5 annex A
Bandwidth (Up/Down) [kbps/kbps]: 443 / 17,499
Data Transferred (Sent/Received) [kB/kB]: 0.00 / 15.00
Output Power (Up/Down) [dBm]: 12.5 / 0.0
Line Attenuation (Up/Down) [dB]: 12.5 / 24.5
SN Margin (Up/Down) [dB]: 31.0 / 2.5
Loss of Framing (Local/Remote): 22 / 0
Loss of Signal (Local/Remote): 3 / 0
Loss of Link (Remote): 0
Error Seconds (Local/Remote): 428 / 0
FEC Errors (Up/Down): 0 / 0
CRC Errors (Up/Down): 0 / 45,028
HEC Errors (Up/Down): 0 / 34,951
EDIT just seen a post about problems with PRO add on, could this perhaps be something to do with this? Thanks
05-08-2011 11:38 PM
That may or may not fix the problem but it would certainly allow faster uploads
05-08-2011 11:48 PM
05-08-2011 11:55 PM
Currently looks like there is no queue on the phone
Regards
06-08-2011 12:03 AM
Will see how it goes once it is uncapped.
06-08-2011 12:08 AM
under
Quote Current line speed:
Just to make sure theyre the same...
Do you have any other filters to hand? experienced a similar problem a few years ago and swapping out (and binning the old) filter did the trick... the "BT" branded filters are abit... pants.
Regards
06-08-2011 12:10 AM
15 Mb
Have changed the filter but can check again just to make sure, would I be better off disconnecting from the routers interface directly so as it not to look like a real disconnection (if that makes sense).
06-08-2011 12:13 AM
DONT disconnect at all currently, if theres any "uplift" in speeds / interleaving etc, the DLM should do it automagically
PN Staff: whats the current Interleaving depth set to on the line, on US and DS ? or we on automatic/none?
Regards
edit:
whilst
Quote FEC Errors (Up/Down): 0 / 0
indicates no interleaving - im asking because i know thomsons arent the best at showing correct figures in there.
increasing the interleaving depth on US by 1 may help but you'd lose abit of ping performance (which obviously, isnt good for gaming)
06-08-2011 12:18 AM
No idea what DLM is but you used automagically so it means I don't have to do anything so no need to know
06-08-2011 12:22 AM
But it is basically BTs equipment monitoring the line, how many drops it does, failed throughput etc. and adjusts the speed accordingly -- whilst it can be annoying (slow to change profile etc.) it fits its purpose reasonably well.
Regards
edit: fixed bodged tag
06-08-2011 12:27 AM
Really not very good with techy stuff...I even giggled a little at the stuck BRAS yeah I'm sad I know haha
06-08-2011 12:30 AM
Quote RAMBO - Rate Adaptive Management Box
Dont annoy him, he might talk slurring his words in an inaudable fashion...
Whilst uncapping the US may alieviate the problem, in my personal opinion i think it will (more likely) compound it (but this is good...) it should make the problem easier to identify
Regards
