Speed just took a big dump
- Speed just took a big dump
Re: Speed just took a big dump
09-11-2015 12:32 PM
Most websites still taking ages to load.
Speedtests still coming back fine though with 16ms ping.
09-11-2015 5:06 PM
10-11-2015 7:48 PM
11-11-2015 9:18 AM
Quote from: nightstalk3r Right now all i have running is Metal Gear Solid 5 and even that keeps disconnecting from the servers.
Something is using your connection more than just having a game open. I'm concerned that whatever this is may be causing your issues so it'd be really good to track it down.
Yesterday's usage was 25GB, 30GB was used on the 9th.
11-11-2015 3:19 PM
I've also tried different routers, adsl cables, the engineer that came out also installed a filtered face plate which has also made no difference to the slowdowns.
I use a lot of data im not denying that, but when the slowdowns occur i have shut everything down to try and resolve it but nothing makes any difference.
11-11-2015 4:39 PM
When it on a go slow anything showing in processes that you dont expect?
Also check here: https://portal.plus.net/view_my_broadband_usage/index.php?&strAction=PERIOD
11-11-2015 4:44 PM
12-11-2015 11:38 AM
12-11-2015 11:58 AM
Before you do you need to get into your head what deal you want - what are others offering if you find one you like, ask if they will match it.
One word of caution is that if the problem is in your line between you and the cabinet a move to fibre may not fix it.
I am in that position I have Rein and the "undiscoverable" source is between me and the cabinet and no-one will say categorically if Fibre will help
only option for me would be cable but I do not need the speed and am not prepared to pay.
12-11-2015 12:12 PM
19-11-2015 4:45 PM
23-11-2015 3:29 PM
I have checked your orders and they are all in place and due to go through this week as discussed previously. So no worries on that front
I hope this fixes the slowdown issues you've been getting.
Thanks.
25-11-2015 12:52 AM
25-11-2015 8:19 AM
Quote from: nightstalk3r i don't use P2P during the day, if i need to update any games that use a P2P updater i let them run through the night or when i leave the house.
do you mean that you only kick off updates (or other downloads) at that time or do you do totally stop the P2P process?
I suggest you install NetWorx (free download at the bottom of the page). That will enable you to watch the downloading and upload and confirm whether anything is going on when you see the slow speeds.
If the problem is that you have an unrestricted upload going on in the background you'll still have an issue when you move to FTTC.
26-11-2015 12:43 PM
