Speed just took a big dump
- Speed just took a big dump
Re: Speed just took a big dump
25-09-2015 4:21 PM
28-09-2015 5:04 PM
Any chance i can get a line reset to get my IP profile put back up and back on to fast path?
29-09-2015 11:57 AM
30-09-2015 2:35 PM
It is still on interleave though rather than fast path.
30-09-2015 4:57 PM
01-10-2015 6:28 PM
01-10-2015 7:06 PM
01-10-2015 7:36 PM
Please look at the PlusNet
If it is the same as the profile figure posted above, then you are suffering from the BTw / BTOR hidden stuck profile problem which seems to be plaguing their 20CN service.
01-10-2015 7:45 PM
AR7 DSL Modem Statistics:
[DSL Modem Stats]
US Connection Rate: 448 DS Connection Rate: 8128
DS Line Attenuation: 11 DS Margin: 15
US Line Attenuation: 6 US Margin: 27
US Payload : 66087168 DS Payload: 1497237024
US Superframe Cnt : 226436 DS Superframe Cnt: 226436
US Transmit Power : 0 DS Transmit Power: 0
LOS errors: 0 SEF errors: 0
Errored Seconds: 0 Severely Err Secs: 0
Frame mode: 3 Max Frame mode: 0
Trained Path: 1 US Peak Cell Rate: 1056
Trained Mode: 3 Selected Mode: 1
ATUC Vendor Code: 54535443 ATUC Revision: 3
Hybrid Selected: 3 Trellis: 1
Showtime Count: 2 DS Max Attainable Bit Rate: 10208 kbps
BitSwap: 1 US Max Attainable Bit Rate: n/a
Annex: AnxA psd_mask_qualifier: 0x0000
Power Management Status: L0 DS HLINSC: 0
US ACTPSD: -345 DS ACTPSD: -365
Total init. errors: 0 Total init. timeouts: 0
Showtime init. errors: 0 Showtime init. timeouts: 0
Last showtime init. errors: 0 Last showtime init. timeouts: 0
ATUC ghsVid: b5 00 54 53 54 43 05 10
T1413Vid: 00 00 T1413Rev: 00 VendorRev: 00
ATUR ghsVid: b5 00 54 53 54 43 00 00
[Upstream (TX) Interleave path]
CRC: 0 FEC: 0 NCD: 0
LCD: 0 HEC: 0
[Downstream (RX) Interleave path]
LCD: 0 HEC: 0
[Upstream (TX) Fast path]
CRC: 0 FEC: 0 NCD: 1
LCD: 0 HEC: 0
[Downstream (RX) Fast path]
LCD: 0 HEC: 0
[ATM Stats]
[Upstream/TX]
Good Cell Cnt: 1376816
Idle Cell Cnt: 2690488
Tx Packets Dropped Count: 0
Tx Bad Packets Count: 6
[Downstream/RX)]
Good Cell Cnt: 31192438
Idle Cell Cnt: 42599893
Bad Hec Cell Cnt: 8
Overflow Dropped Cell Cnt: 0
Rx Packets Dropped Count: 0
Rx Bad Packets Count: 0
[SAR AAL5 Stats]
Tx PDU's: 571296
Rx PDU's: 1037563
Tx Total Bytes: 36798186
Rx Total Bytes: 1467679779
Tx Total Error Counts: 0
Rx Total Error Counts: 0
[OAM Stats]
Near End F5 Loop Back Count: 0
Near End F4 Loop Back Count: 0
Far End F5 Loop Back Count: 0
Far End F4 Loop Back Count: 0
SAR OAM Ping Response Drop Count=0
It's not always like this though, it was fine untill about 6:20pm when it slowed to 0.5meg and was pegged at that for about an hour, then it went back to full speed for about 10 minutes and now its stuck between 2 and 3meg.
Also this is the BQM i had running since the line was fixed until about an hour ago, it looks horrific.
01-10-2015 8:20 PM
This is exactly what it did the day before the phone line died last time so im half expecting the phone to be dead again in the morning.
01-10-2015 8:36 PM
01-10-2015 9:44 PM
02-10-2015 9:42 AM
02-10-2015 2:39 PM
02-10-2015 6:38 PM
