Speed issue
- Speed issue
Speed issue
15-05-2008 4:21 PM
My Router stats are:
Downstream Upstream
Data rate (Kbps)
576 288
Noise margin (dB)
23.3 20.0
Output power (dBm)
16.4 11.7
Attenuation (dB)
63.0 31.5
I know i have a huge attenuation, but i read that your noise margin can be lowered to balance speed and stability? if this is true then cant my noise margin be lowered to about 10-15? as most instability faults occur at around 6 dB?
I also heard that removing the bell wire can rid the phone line of some noises that can be picked up through the bell wire.
If someone could clarify this and maybe make some suggestions it would be most appreciated.
Thanks very much
David
Re: Speed issue
15-05-2008 4:23 PM
Quote Data rate (Kbps)
576 288
The 288 upstream tells me you are still on a fixed speed product. The upgrade to Max was altered to an opt-in basis due to the problems that occurred when this was originally released. Let me know if you want moving to the 'upto' 8Mb product and I'll place the modify order for you. It won't cost you any extra and with your line stats you may see a slight increase in speed.
Re: Speed issue
15-05-2008 4:33 PM
That might involve some work sorting out your phone wiring (in your house) though.
Make the change and post your stats.
Re: Speed issue
15-05-2008 4:40 PM
Also I'm wired straight into the Master socket as a BT technician said it was easier to do that. (I think there was some complications)
Ok so to confirm I would like to be upgraded to the Up to 8Mb package. Thanks very much for both of your prompt posts, It has given me renewed faith in my line!
Thanks alot!
David
Re: Speed issue
15-05-2008 4:44 PM
Re: Speed issue
15-05-2008 4:46 PM
Cheers
David
Re: Speed issue
15-05-2008 4:57 PM
Re: Speed issue
15-05-2008 5:14 PM
Re: Speed issue
16-05-2008 8:19 AM
Downstream Upstream
Data rate (Kbps)
3072 448
Noise margin (dB)
5.6 15.0
Output power (dBm)
17.7 12.3
Attenuation (dB)
63.0 31.5
Its amazing! No changes in actual speeds but i know they will be updating that after 3 days.
Thanks alot for helping me sort this out!
David
Re: Speed issue
16-05-2008 9:00 AM
Re: Speed issue
16-05-2008 10:22 AM
I've given your connection profile a bit of a poke.
Try rebooting your router. I suspect you might be in for a nice suprise
Re: Speed issue
16-05-2008 2:46 PM
I will reboot and post as soon as I get home.
Thanks!
David
Re: Speed issue
16-05-2008 4:12 PM
My line stats are:
Downstream Upstream
Data rate (Kbps)
2976 448
Noise margin (dB)
5.6 15.0
Output power (dBm)
17.6 12.3
Attenuation (dB)
63.0 31.5
And after a speed test from http://www.mybroadbandspeed.co.uk/ the results are:
Last night before the changes - 483 kbps (60.4kB/s) 372 kbps (46.5kB/s)
Today after the changes - 1945 kbps (243kB/s) 345 kbps (43.1kB/s)
I just have to say that im so impressed at the speed this was done!
Also one other thing, does this mean the 10 day period doesn't apply now? or can my speed still drop?
Thanks!
David
Re: Speed issue
16-05-2008 4:20 PM
I suspect your line will stabilise and you'll get around a 2 Meg profile.. which is nice..
B.
Re: Speed issue
16-05-2008 4:42 PM
I will try to update with stats over the next ten days!
David
