Speed has got really slow the last few days
- Speed has got really slow the last few days
09-10-2010 6:46 PM
The last few days it has gotten unbearably slow. And when I have run speed tests the download speed is always now around 0.2Mb/s which is awfully slow.
It's just happened in the last 4 days and it seems to be at 0.2Mb/s no matter what time of day it is.
It is getting really frustrating. Why has my speed dropped so much in the last few days?
Here is results of speed test I just ran at 18:52 on 09/10/2010:
Re: Speed has got really slow the last few days
09-10-2010 6:56 PM
09-10-2010 7:05 PM
Download speedachieved during the test was - 190 Kbps
For your connection, the acceptable range of speeds is 400-2000 Kbps.
Additional Information:
Your DSL Connection Rate :2048 Kbps(DOWN-STREAM), 448 Kbps(UP-STREAM)
IP Profile for your line is - 1750 Kbps
dick:quote
09-10-2010 7:10 PM
09-10-2010 7:13 PM
Phone exchange:
INVERNESS MACDHUI
Estimated line speed:
3.0 - Checked on 2010-01-07 18:26:03
Current line speed:
250
09-10-2010 7:19 PM
You must have had a low sync 2 or 3 days ago and the IP profile has recovered but the Plusnet mirror of it hasn't picked it up yet.
You could give them a call and see if you can get them to nudge it manually
10-10-2010 3:09 PM
11-10-2010 12:50 AM
Download speedachieved during the test was - 175 Kbps
For your connection, the acceptable range of speeds is 50-250 Kbps.
Your DSL Connection Rate :0 Kbps(DOWN-STREAM), 0 Kbps(UP-STREAM)
IP Profile for your line is - 250 Kbps
11-10-2010 11:50 AM
I've just checked your line and both BT & PN profiles are now showing 1750. What speed are you getting now?
Jojo
11-10-2010 1:49 PM
I just ran BT speed tester again and I got this:
Download speedachieved during the test was - 177 Kbps
Your DSL Connection Rate :2240 Kbps(DOWN-STREAM), 448 Kbps(UP-STREAM)
And these are the results from speedtest.net:
So it's still running really slow
I did the test at here: https://portal.plus.net/my.html?action=data_transfer_speed ; again:
Phone exchange:
INVERNESS MACDHUI
Current line speed:
1750
But my speed is still really slow...
11-10-2010 4:42 PM
Download speedachieved during the test was - 1465 Kbps
Your DSL Connection Rate :1888 Kbps(DOWN-STREAM), 448 Kbps(UP-STREAM)
Is this about as fast as I can expect from my line?
11-10-2010 5:03 PM
Yes, it seems as though the profile lift was lagging behind a bit. As far as the speed goes, I would expect you to get more than what you are currently getting. Looking at your connections since the 5th it would appear there is an underlying problem. The main thing causing the lower sync rate is the SNR during my test was 16dB. What are your connections like at home, are you using any extensions etc? Are you in the master/test socket?
Jojo
11-10-2010 5:49 PM
What sort of speed should I be able to get? I know the Inverness exchange is suppose to be pretty poor compared to the rest of the UK.
11-10-2010 6:28 PM
Download speedachieved during the test was - 196 Kbps
Your DSL Connection Rate :2752 Kbps(DOWN-STREAM), 448 Kbps(UP-STREAM)
12-10-2010 12:44 PM
Download speedachieved during the test was - 198 Kbps
Your DSL Connection Rate :2784 Kbps(DOWN-STREAM), 448 Kbps(UP-STREAM)
IP Profile for your line is - 1500 Kbps
It looks like PN still have my profile at 250kb 😕
Phone exchange:
INVERNESS MACDHUI
Current line speed:
250
