Speed goes from 6.5Mbps to 2.5Mbps - Help
- Speed goes from 6.5Mbps to 2.5Mbps - Help
Re: Speed goes from 6.5Mbps to 2.5Mbps - Help
13-03-2010 8:19 PM
Download Speed
3677 Kbps
0 Kbps 4000 Kbps
Max Achievable Speed
Download speedachieved during the test was - 3677 Kbps
For your connection, the acceptable range of speeds is 600-4000 Kbps.
Additional Information:
Assured Rate IP profile on your line is - 4000 Kbps
Actual Data Rate
Up Stream
448 (Kbps.)
Down Stream
7488 (Kbps.)
Operation Data
Upstream
Downstream
Noise Margin
28 dB
15 dB
Attenuation
23 dB
24 dB
13-03-2010 8:42 PM
Quote from: spraxyt Does the router have a button to disconnect from Plusnet without re-syncing, then reconnect? That can be useful to pick up the new service profile when the Member Centre Current line speed increases.
Yes... just found disconnect and connect buttons on the main screen that appears to disconnect from the web without rebooting
14-03-2010 12:05 AM
Your sync speeds seem to be changing but it isn't clear whether the change results from the connection dropping, or a forced restart. In your opening post you mentioned the connection starting at a reasonable speed, then falling over time. Does that still happen with the Belkin router you are now using? I think the best way to check that would be to leave it on 24x7 for a few days and record sync speeds, attenuations and noise margins at similar times each day - plot them manually against date/time using a spreadsheet and post the result. (Attenuations should remain (almost) constant.) That would present the information in a more easily assimilated format.
If the sync speed changes try to work out when this happened (from up-time), but don't restart the router unless the new sync speed is excessively low. In this case it will be necessary to restart the router to increase the sync speed again.
14-03-2010 10:31 AM
I agree, I'll keep a track manually and leave it alone for a while. Routerstats software sort of works but keeps putting the wrong data in the wrong fields in the graphs even when I manually configure it.
I had to turn it off last night briefly as I needed to move the snakes nest of cables from the old router wires etc but it's been up since.
I'm taking screen grabs to build up a spreadsheet. Here is this mornings.... BT SPEEDTEST followed by ROUTER stats. Downstream Noise and attenuation seems to be stable at around 15 and 24 respectively.
Does the Interleaved Path FEC Correction of 2329 have any significance?
Download speedachieved during the test was - 1758 Kbps
Your DSL Connection Rate :7296 Kbps(DOWN-STREAM), 448 Kbps(UP-STREAM)
IP Profile for your line is - 6000 Kbps
Status
Configured Current
Line Status --- SHOWTIME
Link Type --- Interleaved Path
Date Rate: Data Rate
Stream Type Actual Data Rate
Up Stream 448 (Kbps.)
Down Stream 7296 (Kbps.)
Operation Data / Defect Indication: Operation Data
Operation Data Upstream Downstream
Noise Margin 28 dB 15 dB
Attenuation 23 dB 24 dB
Defect Indication
Indicator Name Near End Indicator Far End Indicator
Fast Path FEC Correction 0 0
Interleaved Path FEC Correction 0 2329
Fast Path CRC Error 0 0
Interleaved Path CRC Error 0 3
Loss of Signal Defect 0 ---
Fast Path HEC Error 0 0
Interleaved Path HEC Error 0 0
Statistics: Statistics
Received Cells 1082896
Transmitted Cells 100186
14-03-2010 1:39 PM
On my own line if the sync speed is higher than its 'comfort' value the rate at which FEC errors builds up increases, and the router eventually tends to re-sync on its own, usually in the small hours so the sync speed reduces.
Self-configured Routerstats can be troublesome when the format of numbers changes through the addition of an extra digit. It's possible John (the author of Routerstats) might be able to create a more robust router-specific .ini file for the router if you contact him with the information set out on his betatesters page.
14-03-2010 7:29 PM
Nothing much happening with my router,,, sync speeds unchanged since previos post and downstream SNR varying between 13 and 15 and attenuation @ 24, speed test showing c 1.7Mbps.
I've lived with this kind of speed for years, probably due to turning the router off daily and it dropping connections 'cos it was knackered. Now BBC i-player is active on my Humax Freesat I need 2 minimum and ideally 4Mbps and seeing 6.5..... albeit only for a few days, seemed like heaven!! (and what I'm paying for. )
14-03-2010 9:58 PM
My suggestions were aimed at justifying a training reset - it is a waste of time if problems with the line (or your equipment) take you back to square one within a few days. So patience is called for, see if you can justify a reset.
14-03-2010 10:47 PM
I'm going to have to reboot the router as I need to set up security. When I set it up a day or so ago I left it unsecured for quickness... mind you I live 200 yards from the nearest country road so freeloaders shouldn't be a problem.
Coincidentaly I helped my neighbour tonight set up his new netbook and his virgin connection was only giving him 0.5MBps tonight and he's sharing ther same telegraph poles and copper down to the cottages.
14-03-2010 11:32 PM
Restarting the router once to set-up security is OK, it is one you can explain. I suggest doing it during daylight hours to get the highest sync possible.
Interesting information about your neighbour's connection. Hopefully you'll be recommending Plusnet to him soon.
14-03-2010 11:55 PM
I'll get onto Plusnet to restart the training period in a couple of days when it's hopefully been stable for 3+ days.
19-03-2010 2:47 PM
The engineer was here all of 5 minutes and plugged his router/laptop into my master socket , ran a quick test and said the line was Ok and no faults. Spoke to Plusnet who now say, yet again, wait 72 hours, reboot the router and see if there is an improvenmet.... been ther, done that, worn the t-shirt for the last 3 months!
Router Stats, as below, have been consistant for days bow with downstream Snr 15DB and attenuation 24DB..... and downstream 2592.
My 72 hours takes me into Saturday.... but I'm not holding my breath!
ADSL Status Information
1. Status: Status
Configured Current
Down Stream 2592 (Kbps.)
Noise Margin 20 dB 15 dB
Defect Indication
Interleaved Path FEC Correction 1632 1036
Interleaved Path CRC Error 1 0
Received Cells 6209907
Transmitted Cells 636115
20-03-2010 2:21 AM
20-03-2010 10:14 AM
I have that deja vu feeling.
21-03-2010 10:04 PM
1. Status: Status
Configured Current
Down Stream 6272 (Kbps.)
Noise Margin 28 dB 2147483647 dB
Attenuation 23 dB 23 dB
Defect Indication
Interleaved Path FEC Correction 55488 22484028
Interleaved Path CRC Error 1128 19938
Loss of Signal Defect 10 ---
Interleaved Path HEC Error 204 0
Received Cells 4508350
Transmitted Cells 518494
22-03-2010 2:44 AM
