Speed fault reported 5 days ago, awaiting support team
- Re: Speed fault reported 5 days ago, awaiting supp...
10-04-2010 12:30 PM
Hi, reported terrible speed loss Monday 5th (32816386) and as yet no reply from the support team. Speed was about 4.5M now about 190 Kbps for over a week now. Was once as low as 83 Kbps according to BT speedchecker. Help please. Derek
Message 1 of 5
(1,176 Views)
4 REPLIES 4
Re: Speed fault reported 5 days ago, awaiting support team
10-04-2010 1:26 PM
Can you post:
We'll then advise further.
- the results from a BT speed test
- the current line speed reported on this page
- the stats reported by your router - sync speed, attenuation and noise margin (this page has instructions on how to find these figures for lots of routers)
Message 2 of 5
(578 Views)
10-04-2010 3:47 PM
Hi, BT speedtest:-
FAQ
Results Image not loaded
Test1 comprises of Best Effort Test: -provides background information.
Download Speed
192 Kbps
0 Kbps 7150 Kbps
Max Achievable Speed
Download speedachieved during the test was - 192 Kbps
Additional Information:
Your DSL Connection Rate :6464 Kbps(DOWN-STREAM), 448 Kbps(UP-STREAM)
IP Profile for your line is - 5500 Kbps
This test was not conclusive and further testing is required.This might be useful for your ISP to investigate the fault.
If you wish to carry out further tests,please click on 'Continue' button.If not, please close the window using 'Exit' button and contact your ISP for further assistance with these results.
Please visit FAQ section if you are unable To understand the test results.
Current line speed:Phone exchange:
THAMESMEAD
Estimated line speed:
5 - Checked on 2010-03-21 23:04:49
Current line speed:
5500
Router_sync etc:System Up Time 124:16:07
Port Status TxPkts RxPkts Collisions Tx B/s Rx B/s Up Time
WAN PPPoA 1029105 861444 0 431 1157 115:44:03
LAN 10M/100M 871294 1060491 0 1169 463 124:16:02
ADSL Link Downstream Upstream
Connection Speed 6464 kbps 448 kbps
Line Attenuation 32 db 10 db
Noise Margin 12 db 19 db
Hope all this is of help, Cheers
FAQ
Download Speed
192 Kbps
0 Kbps 7150 Kbps
THAMESMEAD
Current line speed:
5500
Message 3 of 5
(578 Views)
10-04-2010 3:51 PM
Can you try disconnecting/reconnecting and then run a speed test again.
I'm wondering if you had something that caused a low speed sync which push your IP profile way down. Sometimes the PN systems need a reconnect to recognise when it has gone back up.
Message 4 of 5
(578 Views)
10-04-2010 4:18 PM
Cheers jelv, rebooted the router and speed now up to 5.11mb yer a true gent sir, pity the support team couldn't be as quick or good as your goodself.
Message 5 of 5
(578 Views)
