Speed dropped to 380kbs
- Speed dropped to 380kbs
Re: Speed dropped to 380kbs
05-09-2018 7:57 PM
15-09-2018 1:38 PM
15-09-2018 1:40 PM
@grimples I have removed the fix for you.
16-09-2018 3:13 PM
Hi @grimples
Thanks for coming back to us and thank you @Strat for removing the fix marker.
@grimples - you will recall that we spoke a few weeks ago regarding the next steps for investigating your loss of speed. At that point in time, you declined the offer of sending an engineer and indicated that you intended to seek out an alternative provider.
Just to reiterate - we are happy to raise this as a fault with the caveat that the visit is likely to be chargeable as no fault is evident at this stage.
Please let us know if you'd like to pursue this route - without allowing us to send an engineer to your premises, I'm not sure how else this thread will ever be marked as 'Fixed'?
Best wishes,
Dave
17-09-2018 2:09 AM
17-09-2018 8:14 AM
If your minimum term if your contract is approaching then you should contact COTS immediately to see what new deal you can get to avoid being face with higher costs when the introductory discount ceases.
@staff
Has setting the DS profile to 3dB been tried?
What’s the estimated line length here please? Is the line well balanced?
This line performance suggests it is long possibly rural so fibre is not likely to be brilliant ... is that where the reference to 11mbps came in?
17-09-2018 2:35 PM
17-09-2018 2:41 PM
There was a typo in the post on the phone number. The correct details are:
Please perform a quiet line test - dial 17070 select option 2 using a corded phone plugged into the test socket behind the face plate of the master socket. It should be silent. A noisy phone line (or no dial tone) will have a marked adverse impact on the performance of broadband.
17-09-2018 2:41 PM - edited 17-09-2018 2:43 PM
That's because it was a typo in Townman's post, the number is 17070.
oops Spendlesstime beat me by a few seconds.
17-09-2018 2:43 PM
17-09-2018 2:44 PM - edited 17-09-2018 2:45 PM
@grimples As @Townman has advised the issues here are due to the physical line rather than any package restrictions
The current target is 9db and the line quality is green so we can try a drop to 3db however if the line starts to error then DLM will likely increase it.
With regards to the line length it's currently estimated at 3.5km. I'm not sure where the reference to 11mbps has come from as the estimates for fibre are quite good as shown below
Featured Products |
Downstream Line Rate(Mbps) |
Upstream Line Rate(Mbps) |
Downstream Handback Threshold(Mbps) |
WBC FTTC Availability Date |
WBC SOGEA Availability Date |
Left in Jumper |
High | Low | High | Low | ||||||
VDSL Range A (Clean) | 80 | 67.8 | 20 | 19 | 60.5 | Available | Available | -- | |
VDSL Range B (Impacted) | 80 | 62 | 20 | 19 | 51.7 | Available | Available |
17-09-2018 2:50 PM
17-09-2018 7:39 PM
I'm not sure how you'd test your speed with YouTube, but could you run a speed test at http://www.thinkbroadband.com/speedtest instead letting us know the results?
17-09-2018 8:51 PM - edited 17-09-2018 8:55 PM
I could BT test till am blue in the face, they dont do anything that my readings from Netmeter do. I will repeat: Netemeter settings have never been changed for years, it has never been updated. For a quite a long time it shows i am getting a steady 480KiB/s then it shows i am getting 380KiB/s then a few days later it shows i am getting 350KiB/s, why would it do this if i have not done any changes to Netmeter or any changes to my browsers or my system, i know of no other way to explain this situation.
Whatever you(or whoever) messing with earlier has decreased my speed again, it's 20KiB/s but it all mounts up.
17-09-2018 10:57 PM
The BT Speed test transfers data under full-load, under stress and is the bench mark for profiling speed issues. It reports mbps (bits) of pure data transfer, with the PC not needing to do anything with the data recieved.
What "netmeter" tool are you using? https://www.netmeter.co.uk/speed-test/ reports speeds in mbps as well, not the KiBps units you are reporting.
There's a tool called "Net Meter" and others with similar names for Android platforms.
BT line speed tests are the litmus test - what others beside the BT one have you tried? It is not uncommon for there to be a variation between them, for they each have their own approach to stress loading the connection … which is a passing thought … can you be sure that what is being reported by your "Net Meter" is actually working under full stress load and not simply just going as fast as it needs to … or only as fast as your PC can cope with, concurrently doing file transfer whilst rendering the video content?
Does anyone here have any knowledge of how much "guts" this monitoring tool uses of the PC's resources?
