Speed dropped to 2.6mbps
- Speed dropped to 2.6mbps
Re: Speed dropped to 2.6mbps
30-08-2018 10:09 PM
Hi I have updated the ticket and it requested i posted here when done
31-08-2018 10:18 AM
31-08-2018 10:51 AM
31-08-2018 11:24 AM
31-08-2018 1:32 PM
31-08-2018 1:36 PM
31-08-2018 10:46 PM
Lovely thanks very much
01-09-2018 12:09 PM
03-09-2018 4:52 PM
Hi
Had the engineers visit and it appears to be a problem your end something to do with DNS and you stopping my connection your end as my line was syncing at over 5mbp/s and up to 6 at times when he was here but it also dropped and said I was when it was clearly not working.
03-09-2018 5:52 PM
There aren't actually any engineer notes against the job so I contacted our suppliers for confirmation and all they could say is there were some external changes made to the connection.
This was your line stats before the visit:
Test Executed On: | 2018-08-30 T19:03:58.799Z | ||||||||||||||||||||||||||||
xDSL Status Test Summary | |||||||||||||||||||||||||||||
Sync Status: | Circuit In Sync | ||||||||||||||||||||||||||||
General Information | |||||||||||||||||||||||||||||
NTE Status: | NTE Power Status: | PowerOn | Bypass Status: | ||||||||||||||||||||||||||
Indicative Line Quality: | R |
Current BRAS Profile(CVLAN rate): | 3381 |
This is after the visit:
Test Executed On: | 2018-09-03 T17:34:19.505Z |
Indicative Line Quality: | A |
Current BRAS Profile(CVLAN rate): | 5742 |
There's a noticeable difference there with line quality is showing as improved with a 2 meg increase in sync. The data from the increase hadn't filtered through to the account so that still had the lower profile. I've just updated that and it should be noticeable shortly.
03-09-2018 8:37 PM - edited 03-09-2018 8:38 PM
Well to be honest most of that means nothing to me what I can say was I had a connection of about 5mbp/s till early evening when it stopped working again I have just checked and it is back and the speed has now dropped again back to roughly 2.8mbp/s
He did say his report will be passed back to,Plusnet so maybe that hasn’t been done yet
04-09-2018 12:06 PM
04-09-2018 10:25 PM
When you say the lower end of speed I was getting a reliable 4.5 mbps till recently when it dropped to roughly 2.5 mbps it has even risen to the breakneck speed of 5.05 mbps and according to he engineer syncing at over 6 mbps tonight it has dropped again to a paltry 1.4 mbps, the engineer said it was down to you stopping my connection something regarding a DNS error so I would say there is still a problem your end that need fixing please
05-09-2018 11:48 AM
Hi @mkc66
I have reset your line for you, and also updated your ticket at https://www.plus.net/wizard/?p=view_question&id=182167494
05-09-2018 2:02 PM
Well for the last 2 to 2 half hours there has been no usable. Internet even though the router says connected !!
