Speed dropped ticket #67862626
- Speed dropped ticket #67862626
04-04-2013 4:54 PM
I raised a ticket #67862626 last night.
Sometime between 10:56am and 9:38pm 3 April, my broadband had a fit, my speed dropped from 13.73 to 2.27 Mbps. (I have a nasty habit of checking such details!). Tried the "Gateway Hop" but didn't resolve anything. Final resort closed down Internet connection, and powered the router off and back on. Still no joy.
I ran BTW Performance Test (wished I took a screenshot now) and prompted me to run a TAP3 test, which I did.
Bit of a surprise result though (in the previous 2 tests it had reported download speed approx 2 Mbps) as it came back with:
BT Performance Tester Tool indicates poor service throughput after 3rd test
13.86 Mbps Download
0.01 Mbps Upload
So... I guess its one way to say there's a problem with my line, and report incorrect figures!
As it currently stands, Speedtest.net reports Download 2.27Mbps, Upload 1.00Mbps
Plusnet Current line speed: 2.4Mb (Estimated 11Mb)
I usually get Download: 13-14Mbps, Upload: 1.00Mbps
Here's the stats from my router:
xdsl info expand=enabled
Physical Layer Statistics:
Modem state: up
Up time (Days hh:mm:ss): 0 days, 17:00:41
xDSL Standard: ITU-T G.992.5
xDSL Annex: Annex A
Channel Mode: Interleaved
Number of reset: 1
Chipset Vendor info (G.994.1): Local Remote
Country code: B500 B500
Specific: 0000 71BE
System Vendor info (showtime): Local Remote
Country code: 0F00 0000
Specific: 3C61 0000
Bearers generic info DS US
Payload rate [Kbps]: 16344 1239
Attenuation [dB]: 28.5 13.8
Margins [dB]: 9.1 6.0
Output power [dBm]: 0.0 12.8
Number of bearers: 1
Bearer 0 DS US
INP [DMT symbols]: 1.03 0.20
Delay [ms]: 6.79 5.95
Depth []: 96 0.00
R: 12 0
G.997.1 Statistics (last 24 hours):
Failures:
Line failures Near end
Loss of signal (LOS): 1
Loss of frame (LOF): 9
Loss of power (LPR): 0
Performance monitoring:
Line PM: Near end
Error second (ES): 90
Channel PM: Near end Far end
Bearer 0:
Code Violation (CV): 99 7
FEC: 9138028 22
ATM data path PM: Near end Far end
Bearer 0:
HEC violation count (HEC): 1324 N/A
Checked the Exchange and it showed Green. Now to sit back and wait for a response I guess, unless I've missed any other info?
*Edit* I'm wired, and quiet phone line tested too
13.86 Mbps Download
0.01 Mbps Upload
Modem state: up
xDSL Annex: Annex A
Number of reset: 1
Specific: 0000 71BE
Specific: 3C61 0000
Bearer 0 DS US
Depth []: 96 0.00
R: 12 0
Failures:
Line PM: Near end
Bearer 0:
FEC: 9138028 22
Bearer 0:
Message 1 of 5
(866 Views)
4 REPLIES 4
Re: Speed dropped ticket #67862626
04-04-2013 5:03 PM
Hi MsDizzie,
I've run through the usual checks and it's not showing anything out of the ordinary, our faults team will test your line and we'll update you as soon as we have further information.
Chris.
Chris.
Message 2 of 5
(424 Views)
04-04-2013 6:46 PM
Very odd... thanks chrispurvey, I'll wait to see what the faults team find out
Message 3 of 5
(424 Views)
05-04-2013 2:31 PM
Quote from: chrispurvey
Actually there was something out of the ordinary
Duaine from the Faults Team spotted it as:
Fault located to WP profile being set at 2400 / Now updated to 14400 (there's a BIG difference!)
Now I'm happy again
Message 4 of 5
(424 Views)
05-04-2013 2:34 PM
It look's like it had changed after I checked, glad that's sorted for you either way
Message 5 of 5
(424 Views)
