Speed drop and usage?
- Speed drop and usage?
05-06-2009 10:34 AM
my speed has dropped from 2.8Mbps to 2.2Mbps between the hours of midnight to midday. This is the period when i'm not throttled. Also in my account i notice that all my usage is recorded as peak time usage (midday - midnight) when it definately is not.
i use usenet a lot an all my d/l is done mainly after midnight so how come i have midnight - midday usage recorded as 0 for everything?
Also what is the significance of the usage bar ending at 68Gig?
Thks in advance.
Re: Speed drop and usage?
05-06-2009 10:37 AM
On unlimited all usage is currently shown as peak - this is being addressed - but this will have no effect on your speeds.
The usage bar scale is dynamic so the more you use the higher the top end figure
05-06-2009 10:38 AM
The usage chart doesn't matter that much for you, unless you are interested in how much you use.
Is it possible that you've sycnhed lower at some point recently to cause your speed to drop?
EDIT: Jim has his speedy fingers on
05-06-2009 10:48 AM
my router synch seems to be stuck last couple days also....
Conn rate 448/4512
LA 29.0/47.0
SN 22.0/9.5
doesn't matter what time of day or night i reconnect its always the same.
05-06-2009 10:51 AM
it said throughput 2.2Mbps.......normally its 2.8
05-06-2009 10:55 AM
05-06-2009 10:58 AM
that seems ok then
05-06-2009 11:22 AM
05-06-2009 11:28 AM
Everything looks absolutely fine.
I wouldn't rely on the bt site for speed test results.
05-06-2009 11:40 AM
Phone exchange:
YEOVIL
Estimated line speed:
1.0 Mbps - Checked on 2009-05-08 18:49:25
Current line speed:
3000
05-06-2009 11:47 AM
If you manage to keep your synch for 3 days at your current speed you may see a bit of an increase.
05-06-2009 11:51 AM
