Speed as dropped for no reason.
- Re: Speed as dropped for no reason.
30-03-2014 11:22 PM
For months I've been synced at around the 11000Kbps mark and happily downloading at 1.1Mb, then tonight the ADSL light on the router goes off and when it reconnects a few seconds later I'm synced at 8200Kbps. I go to check my current line speed here - https://portal.plus.net/my.html?action=data_transfer_speed - and find it's at 7Mb.
Where has my speed gone? Why has it dropped when nothing has changed How can I get it back again?
Message 1 of 4
(818 Views)
3 REPLIES 3
31-03-2014 1:23 AM
Give it a few hours, restart router and see what happens
Message 2 of 4
(502 Views)
31-03-2014 4:02 PM
It seem they few disconnections you've had have caused your sync rate to decrease.
<img src="http://community.plus.net/visualradius/generated/image13962778735292.png"/>
Do you know if you've had any interference/crackling on your phone line?
Message 3 of 4
(502 Views)
31-03-2014 8:54 PM
Phone line is fine, no noise on the line whatsoever.
Message 4 of 4
(502 Views)
