Speed Thread (Before and after transfer speed comparisons)
chillypenguin
Re: Speed Thread (Before and after transfer speed comparisons)
As Mark said Moderation of the link:pug board is shared between the PUG and the `Community Moderators`. And as the PUG is helping to correlate issues with projects, such as Ironport and the 21CN trials the boards are placed under their section.
What is missing is any reference to this arrangement in the main link:rules, guess what I get to do this weekend  Wink
Word_Warrior
Oooooo, Eck! Is this  the lull before the storm?
scootie
santa's coming tomoro then word warrior Wink can't wait to see what the sync increases are like on the adsl under 4000kbps lines every kbps is well needed in this area
Word_Warrior
Quote from: ASBO
The only thing is.....
I'm having to go to a job in Ipswich tonight and I won't now be back till late tomorrow night (I'm guessing 21.00 - 22.00 at best) Probably be too tired to switch off modem and on again and so forth so you guys will have to wait for an update.
Thanks for your interest Asbo dog  Smiley
Of course the change might not happen until late anyway.
Will keep you posted.
gm4jjj
I will be really interested to see how things go here, as I have 60dB atten on my line and have to frig the modem to get it to use a lower S/N ratio as it stands. I get 3392 sync rate on a good day.  2500 is max stable rate here at present. My main hope is that changes to my BRAS profile don't take so long to recover from in future. I also pay for the faster upload speed here and get 736 upstream sync.
gm4jjj
Before 21 CN (yesterday)
Sync 3392 down 736 up Att 59.5dB S/N 9.8dB (forced)
BRAS 2500
Speed test 2314 down 619 up
After 21CN (today)
ADSL2+ forced with DMT tool
Sync 3782 down 600 up Att 60db S/N 9.6db (forced)
Speed test 2333 down 509 up
ADSL1 forced with DMT tool
Sync 4096 down 736 up Att 56dB  forced S/N 10dB
Speed test 2252 down 646 up
ADSL2 forced with DMT tool
Sync 3854 down 695 up Att 55dB
Speed test 2312 down 570 up
UPDATE 1
NOW with forced ADSL1
Sync 4128/768
Speeds increased to 3168 down 651 Up
Notes: all are interleaved.
Router Netgear DG834N firmware V1.02.08
UPDATE 2 despite getting 4128 sync on ADSL 1 now, the BRAS profile appears to be clamping downloads to 2500 (2332 measured). Hopefully this will go back up to over  3000 again.
pnf
My line has just been switched over.  The changeover was seemless, the lights on my router alerted me to the fact that something was going on.  Below is the information from my router prior to and after the switchover:
Router Information -  ADSL:
Modulation: G.992.1 annex A
Bandwidth (Up/Down) [kbps/kbps]: 448 / 8,096
Output Power (Up/Down) [dBm]: 11.5 / 19.5
Line Attenuation (Up/Down) [dB]: 16.5 / 30.0
SN Margin (Up/Down) [dB]: 22.0 / 10.0
Router Information - ADSL2+:  (uptime:  0 days, 0:02:27)
Modulation: G.992.5 annex A
Bandwidth (Up/Down) [kbps/kbps]: 1,000 / 12,211
Output Power (Up/Down) [dBm]: 12.5 / 22.5
Line Attenuation (Up/Down) [dB]: 17.0 / 33.0
SN Margin (Up/Down) [dB]: 8.0 / 6.0
I will carry out speedtests and post them later.  It will be interesting to see how things settle down over the 7 day training period.
VileReynard
Fixes: 20
I'm not sure speed results are of a lot of use.
My download sync rate has increased from about 7648kbps to only 8517kbps
I think that my BRAS limiter is unchanged.
I am getting a lot of TCP re-transmits, which is causing a lot of sluggish browsing.
My router is not showing any difference in the way it connects - is this right?
James
Have you tried rebooting your router?
VileReynard
Fixes: 20
Thanks James.
I have a Netgear DG834GT - before rebooting I had no connectivity, I now have the connectivity previously described.
zubel
Try forcing G.992.3 mode on the router:
http://your.router.ip.address/setup.cgi?next_file=dsl_cfg.htm&todo=cfg_init
and select "ADSL2"  under "DSL Mode", then apply and reboot router again.
B.
VileReynard
Fixes: 20
I wonder if I have the right kind of firmware?
I only get a choice of
    *  Multiplexing Method - Your ISP will indicate whether your Multiplexing Method is VC-BASED or LLC-BASED.
    * Virtual Circuit - Your ISP will indicate which VPI/VCI combination is used for your service.
My firmware is V1.02.04
James
Fancy trying to upgrade to the latest version of firmware, whilst keeping a copy of the existing firmware?
Whilst it may not achieve anything, it would be interesting to see if it makes any difference.
Oldjim
Resting Legend
Fixes: 63
This is what it looks like on my DG834G which uses the same chipset as the GT
Edit - I enable debug mode so that may be the difference http://192.168.0.1/setup.cgi?todo=debug
greyposter
Today 14:41 5633 kbps (704kB/s) 894 kbps (112kB/s)
Today 14:40 5240 kbps (655kB/s) 892 kbps (112kB/s)
Today 09:55 5913 kbps (739kB/s) 316 kbps (39.5kB/s)
Today 09:07 5766 kbps (721kB/s) 326 kbps (40.8kB/s)
Upload has increased but not download but it's been on only since 9:00.
