Speed Tester
- Re: Speed Tester
Speed Tester
31-01-2008 12:23 PM
Hi, I was activated on Wednesday of this week and I thought I would test my speed using the tool in the My account area, I'm getting some weird readings, a couple of zeros and this morning 140 mbps. i usually use either Namesco or Speedtest.net. I do them now and again just to keep a record.
could anyone advise what may be wrong, I run Norton Internet security 2008 with Phishing protection and I'm using Vista Home Premium Op system.
regards
jono
regards
jono
Message 1 of 6
(1,273 Views)
5 REPLIES 5
Re: Speed Tester
31-01-2008 12:26 PM
The tester on the portal is rubbish and due for replacement.
Try http://www.mybroadbandspeed.co.uk/ which is what is going to replace it.
Message 2 of 6
(434 Views)
Re: Speed Tester
31-01-2008 12:32 PM
I've just had a look at your account and done a quick line test and I can't see any problems, it's showing you with a good profile of 7000. Can you try a BT Speedtest and let us know the results.
Message 3 of 6
(434 Views)
Re: Speed Tester
31-01-2008 1:45 PM
Hi Chris these are the results, I haven't got a problem with speed, as i said I usually use other sites but thought with being new to plus net i would give the one on the site a try.
Test1 comprises of Best Effort Test: -provides background information.
IP profile for your line is - 7000 kbps
DSL connection rate: 448 kbps(UP-STREAM) 8096 kbps(DOWN-STREAM)
Actual IP throughput achieved during the test was - 6476 kbps
If you wish to discuss these results please contact your ISP.
If you are experiencing problems with specific applications, servers or websites please contact your ISP for assistance.
Your test has completed please close this window to exit the performance tester.
regards
jono
regards
jono
Message 4 of 6
(434 Views)
Re: Speed Tester
31-01-2008 1:54 PM
Good to know that it's just the portal speedtester giving odd results. As jelv says this isn't particularly good, the new one he has linked to gives much better results.
Message 5 of 6
(434 Views)
Re: Speed Tester
31-01-2008 2:11 PM
Hi just tried that one and the results as you say are ok, thought I'd sort the one out on the Plus net site out just in case I have bother but so far I'm over the moon, good servce all round.
Today 14:07 6541 kbps (818kB/s) 364 kbps (45.5kB/s)
Thanks for the help anyway.
jono
jono
Message 6 of 6
(434 Views)
