Speed Problems
FIXED- Subscribe to RSS Feed
- Re: Speed Problems
16-04-2020 9:42 PM
Currently having problems with the download speed of my ADSL.
Stats from the Draytek 2862 router are
Profile according to Plusnet
BTW Test check results
Anyone available to have a look as there's something not adding up here and my speed is crippled
Fixed! Go to the fix.
17-04-2020 11:34 AM
Thanks for getting in touch @Ravinella
I'm sorry to hear that you're having issues with your connection.
I've tested your line and it appears it's dropping quite often and our tests have also highlighted a fault on the phone line known as an 'Earth Contact'
Unfortunately as we aren't your phone provider we can't report this for you so I'd recommend contacting your phone provider so that they can get that resolved for you
Re: Speed Problems
17-04-2020 3:06 PM
