Speed Issues - Frustration setting in
- Speed Issues - Frustration setting in
Re: Speed Issues - Frustration setting in
14-01-2009 10:35 AM
Have you checked the staus of your exchange - you can do that here. What does it say under "VP Capacity"?
If this is showing as red then it's the likely cause of your problems and there won't be a lot you can do till BT add extra capacity (basically you'll be getting hit by contention). Note - the checker was last updated 15/12/08 so the status may be out of date (it may actually be red even if it says green!).
14-01-2009 10:45 AM
@jameseh - If there is a chance that it may make the connection unstable I think I will leave it as it is as my gaming comes second to internet access. Do you think its worth raising a ticket to see if there are any other issues?
@Paul03 - I have checked the status of my exchange reguarly during the past 2 weeks and yes although it is out of date it has always reported green.
Dave
14-01-2009 11:03 AM
Would you mind reconnecting to the internet so I can check your line? If it's not showing any errors then interleaving being turned off shouldn't be a problem.
14-01-2009 11:14 AM
Unfortunately I am posting this from work and will not be able to reconnect until 1800hrs.
Dave
14-01-2009 11:23 AM
Would you mind leaving it on during the day tomorrow so I can check then?
14-01-2009 11:30 AM
Dave
14-01-2009 4:02 PM
Whilst we deduced your profile is 1500 from your initial post, and there has been a lot of ping and tracert figures in this thread we've not seen any router ADSL stats. This may give us a better idea of what is happening and enable some more informed advice in addition to the results of James' line checks. From your router ADSL stats the figures of interest will be sync speed (line rate), attenuation, Signal to Noise Ratio Margin (SNRM) both Downstream and Upstream.
Regards.
14-01-2009 4:04 PM
14-01-2009 6:46 PM
As requested by Anotherone:
Downstream Upstream
Connection Speed 1920 kbps 448 kbps
Line Attenuation 56 db 15.5 db
Noise Margin 10 db 20 db
14-01-2009 8:17 PM
14-01-2009 8:25 PM
Tonight is probably the best connection I have had for some time, and as Sod's Law dictates, streaming video is actually streaming - typical. Not sure how to get the data on corrected/uncorrected errors!
I will leave my connection on tomorrow while I am at work and let Jameseh take a look.
Dave
14-01-2009 8:28 PM
Connection Speed 1760 kbps 448 kbps
Noise Margin 9 db 19 db
Dave
15-01-2009 8:09 AM
Morning - connection left on today as requested.
Tried to do a bit of online gaming again last night but still terrible!
Dave
15-01-2009 10:11 AM
No obvious line errors (although the test I run is fairly short), with an SNR of 11dB and a sync speed of ~1900Kbps.
Does your router report line errors anywhere at all?
15-01-2009 10:33 AM
I have delved deep into the router setup and cannot find anything relating to line errors, although I have to admit unless it says "These are your line errors" I could be looking at them in the face.
If it appears failry stable then could I have interleaving switched off please? Although I realise this wont solve the other speed issues.
Yesterday evening when I first connected the speed appeared to have resumed to normal - streaming video was fine, however after a short time even very low res video grind to a halt and webpages took an age. However a thinkbroadband speed test and a PN speed test both reported decent speeds. (BT speedtest still wont work even after a Java update)
I just dont get it!
Dave
