Sorry.....But I am sick to death with the problems on my line.
- Sorry.....But I am sick to death with the problems...
Re: Sorry.....But I am sick to death with the problems on my line.
26-10-2012 12:49 PM
Your ticket hasn't been closed, it looks like it was an automated message from our suppliers that prompted this. We are currently monitoring your connection and we just need to wait and see what the outcome is.
26-10-2012 1:00 PM
Get a competent and senior Faults analyst on this, get him back on ADSL1 with a Target SNRM of 6dB and get a REIN eng on the job to track down this interference. If anyone competent read all the relevant information they could see why.
Not good enough Plusnet.
26-10-2012 4:39 PM
That's been picked up by Spencer and your ticket has been updated in detail. We now need to wait for the modify order to complete which will be on Monday.
Chris
26-10-2012 6:13 PM
27-10-2012 8:43 PM
At the start of the capture you will see a period of time when my line/service was rock solid. This was for a 13 day period between 23/08 qnd 05/09. I was maintained a permanent sync at 1.984Mbps during this time... giving a DL profile of 1.75Mbps.........look at how my service has gone since 05/09.
Any conclusions to be drawn, thoughts, speculation?.....Chris?
KR's
Alex
27-10-2012 9:44 PM
27-10-2012 9:46 PM
28-10-2012 9:17 AM
Bearing in mind the modify order that Spencer has placed, it's probably a bit of a wait and see for a few days to see what it's achieving and how it's behaving.
If things don't improve and you still see changes in SNRM and periodic drops, the next step? - personally I would hope that a L&S would be done, it's fairly quick to expedite. If the problems are then still ongoing, then it has to be a REIN engineer.
28-10-2012 9:38 AM
28-10-2012 9:51 AM
28-10-2012 10:02 AM
Actually the average would be quite useful - on the Setup >Graphs tab, in the Noise Margin box, tick the box "Plot average value of previous" 50 points.
Whatever is causing the drop to 5dB would be of more interest.
Do you see many "spikes" these days?
As regards the profile update, the cause is the absence of a timely Delta Report which should automatically get produced by BT's systems and isn't in a number of cases. All ISP's get Delta Report's of their customers' lines. The reports seem to get produced eventually. Yes it's b irritating when you are affected! PN have been chasing this with BT.
28-10-2012 10:49 AM
Anyway the RSL graph for the drop to 5db is attatched.
Spikes......well the way it goes usually is as shown in the group of 4 RSL graphs as earlier in the thread. Scenario: service is quite happy happy at flatish 6db (High sync rate) then a sudden bleed out and resync......after which SNRM will return to 6db (low sync rate) but with obvious noise +/- 0.1 to 0.2 ish spiking (nothing major).....then SNRM will shoot straight up to 10 or 11.....at this point I disconnect from PN and reboot router......SNRM returns to 6 with as high or higher sync rate that I started with! I hope I explain this clearly!
28-10-2012 11:20 AM
Quote from: alex7127 Doh!
You can modify your post to add an attachment.
28-10-2012 11:34 AM
The drop to 5dB (not huge) at ~0635, the sort of time heating might come on somewhere. Is there a regular pattern to this 1dB drop at similar times on particular days of the week at all?
What sort of level is the SNRM at now?
28-10-2012 5:41 PM
1. I feel that the 'drops' to 0db are a loss of sync and not a large burst of noise....but hey who am I?
2. No there is no regular pattern to any 1db drops. I have been this afternoon trawling through my RSL data and cross referring it to when the bolier kicks in and off for both the hot water and central heating........I have found
NO instances where the SNRM has dropped when the bolier has come on AT ALL. I suppose this is good news as we can rule this out?.....unless it is causing intermittant noise??? I am not ruling anything out in my house
as to be the possible cause of noise........but since April this year I have been investigating all and any possible cause. I have yet to find anything that I can test by switching on and off to make any movement on the SNRM
live plotting on RSL
3. SNRM has been between 4 and 5.5 db all day. No resyncs today.....but as I have already said this is not uncommon at the weeked. MOST drops of sync (I shall call them) happen Monday to Friday.....read into this what you
will.
4. Hmmmm maybe yes...I think there may be two types of events going on here. That is loss of sync and noise.
The saga continues......
Kind Regards
Alex
