Something stuck, or is this normal?
- Re: Something stuck, or is this normal?
12-03-2013 6:12 PM
Over on the plusnet connection settings/high speed broadband im getting this
and on the BT speedtest site it says this
And my router reports an uptime of 21 days ( since a brief power cut)
I was under the impression that the IP profile changed every few days is something stuck?
or is this all OK and correct?
Quote Estimated line speed:
14Mb (This may vary between 8Mb and 18.5Mb) - Checked on 2013-01-27 10:28:15
Current line speed:
10.9 Mb
Quote Download speedachieved during the test was - 10.26 Mbps
For your connection, the acceptable range of speeds is 4 Mbps-21 Mbps.
IP Profile for your line is - 10.95 Mbps
Message 1 of 6
(1,121 Views)
5 REPLIES 5
12-03-2013 6:14 PM
The BT IP profile only changes when there is a resync to a different speed
The Plusnet one follows a day or so later
Message 2 of 6
(619 Views)
12-03-2013 6:16 PM
so if i re-boot the router ( un plug it and plug it back in again) would this have a positive effect?
jim:quote
jim:quote
Message 3 of 6
(619 Views)
12-03-2013 6:18 PM
Or a negative one - depends on the new sync speed
The IP profile is 88.2% of the sync speed on ADSL
Message 4 of 6
(619 Views)
12-03-2013 6:26 PM
My IP profile has now remained the same for the past 1140 hours.
Message 5 of 6
(619 Views)
13-03-2013 12:20 PM
Message 6 of 6
(619 Views)
