Someone else using my broadband connection
- Re: Someone else using my broadband connection
25-08-2008 1:37 PM
A friend of mine who is coming on a visit would like to bring her PC laptop to do some work while staying with me. Will she be able to plug into my plusnet broadband connection? I have a BT Voyager 210 Modem/Router from plusnet which also has a yellow ethernet cable. It is 5 months old.
Message 1 of 4
(1,059 Views)
3 REPLIES 3
25-08-2008 1:52 PM
Yes - if one of you uses the USB port and the other the ethernet port
Message 2 of 4
(370 Views)
25-08-2008 2:11 PM
but dont forget it will go on your bill, you should try and use the yellow cable at all times it is a lot quicker than USB
Message 3 of 4
(370 Views)
25-08-2008 2:31 PM
Thank you very much to both of you. I shall bear that in mind.
Message 4 of 4
(370 Views)
