Some sites will not work for me.
- Some sites will not work for me.
- « Previous
- Next »
Re: Some sites will not work for me.
28-05-2008 10:23 AM
The easiest way to make sure, would be to physically remove the mains power from your router.
That way you'll definitely be offline
Message 31 of 37
(350 Views)
28-05-2008 10:24 AM
Well im using wireless, how would i go about disabling that? ^^
Message 32 of 37
(350 Views)
28-05-2008 10:24 AM
Hiya,
If your router has no mains power, wireless won't work either.
Message 33 of 37
(350 Views)
28-05-2008 10:25 AM
Within the router settings there should be an option to disconnect, failing that you should be able to unplug your router from the telephone socket which will have the same effect.
Message 34 of 37
(350 Views)
28-05-2008 11:19 AM
were you able to connect and see what the problem was?
Message 35 of 37
(350 Views)
28-05-2008 11:20 AM
Yep thanks, I connected using your details and got exactly the same problem. I've got a suspicion that it's IP address related, I'll get back to you shortly.
Message 36 of 37
(350 Views)
28-05-2008 3:36 PM
Sorry about the delay responding, got tied up in meetings. I've spoken to Bob about this too and he can't see why this would be happening. Could you raise a ticket with a wireshark capture on when you try to view those sites. We can then look at why and where the traffic is stopping.
http://www.plus.net/support/broadband/troubleshooting/wireshark_video.shtml
Message 37 of 37
(350 Views)
- « Previous
- Next »
