Some sites will not work for me.
- Some sites will not work for me.
27-05-2008 12:59 PM
I try to get on to sites that i could before but it comes up as 'Internet explorer cannot display the webpage' when these
sites i'm trying to acsess definetly exist and are up and also iv'e asked alot of my freinds to view the sites and they say
that it is working.
But what has really ticked me off is that i have just paid for hosting and now i can't even get on the site.
If someone could please help me or sort this out for me that would be great
Re: Some sites will not work for me.
27-05-2008 1:09 PM
27-05-2008 1:17 PM
27-05-2008 1:18 PM
cp:blue There is no need to use bold type, it make you look rude, as it is akin to shouting mod:end
27-05-2008 1:23 PM
Quote from: Exsert No the sites im trying to acsess work for others just not for me
This can be a result of your MTU being set too high - it's just a quirk with some sites and the way the traffic is routed to them.
People using different ISPs may be routed differently so, while you may not be able to access the site, others can.
What sites are you trying to access?
Quote I can get on them though via proxy why is this?
Ditto above as the proxy may send your traffic over a different route.
27-05-2008 1:32 PM
27-05-2008 1:44 PM
27-05-2008 2:13 PM
If you can post up the URL's that you are trying to get to we can try.
27-05-2008 2:35 PM
Also im seriously thinking of changing ISP now as i really need to get on this site and others
The sites im trying to get to are:
www.able-host.com
www.Sythe.org
Both do not work
27-05-2008 2:41 PM
To run a traceroute, click Start, Run, type 'cmd' (minus the quotes) and click OK. In the command window that appears do the following:
tracert www.Sythe.org
And then press Enter. You should see something like this:
C:\Users\Bobby>tracert www.Sythe.org
Tracing route to sythe.org [72.52.193.149]
over a maximum of 30 hops:
1 1 ms <1 ms 1 ms home.gateway [192.168.1.1]
2 32 ms 37 ms 35 ms 32.core.plus.net [195.166.128.32]
3 31 ms 31 ms 44 ms 84.92.5.98
4 42 ms 44 ms 33 ms te2-2.pte-gw1.plus.net [212.159.0.186]
5 36 ms 31 ms 38 ms te2-4.pte-gw2.plus.net [212.159.1.102]
6 38 ms 31 ms 32 ms 80.239.193.141
7 41 ms 33 ms 30 ms ldn-bb2-link.telia.net [80.91.248.94]
8 103 ms 112 ms 112 ms nyk-bb2-link.telia.net [80.91.248.254]
9 106 ms 105 ms 105 ms nyk-b5-link.telia.net [80.91.248.162]
10 117 ms 103 ms 126 ms level3-ic-120265-nyk-b5.c.telia.net [213.248.90.
126]
11 106 ms 111 ms 105 ms vlan89.csw3.NewYork1.Level3.net [4.68.16.190]
12 119 ms 104 ms 108 ms ae-82-82.ebr2.NewYork1.Level3.net [4.69.134.89]
13 124 ms 137 ms 136 ms ae-2.ebr1.Chicago1.Level3.net [4.69.132.65]
14 138 ms 147 ms 141 ms ae-11-55.car1.Chicago1.Level3.net [4.68.101.130]
15 135 ms 136 ms 150 ms WBS-CONNECT.edge5.Chicago1.Level3.net [4.71.182.
14]
16 180 ms 172 ms 184 ms lw-core3-ge10.rtr.liquidweb.com [209.59.157.133]
17 177 ms 182 ms 182 ms lw-dc2-dist1-ge1.rtr.liquidweb.com [209.59.157.9
8]
18 148 ms 143 ms 133 ms new.yandros.net [72.52.193.149]
Trace complete.
27-05-2008 2:43 PM
27-05-2008 3:12 PM
2 30ms 25ms 35ms 1o0-plusnet.thn-ag3.plus.net [195.166.128.80]
3 44ms 31ms 28ms v1303. thn-gw2.plus.net
bla bla
it all seems fine then when it comes up to 10 this is what happens;
10 * * * Request timed out.
11 * * * Request timed out.
12 * * * Request timed out.
13 * * * Request timed out.
14 * * * Request timed out.
15 * * * Request timed out.
16 * * * Request timed out.
then it does the same all the way up to 30
so does anyone know what is wrong?
27-05-2008 3:45 PM
27-05-2008 3:50 PM
Quote from: Bob What does line 9 say?
9 130 ms 125 ms 133 ms atlnode1.theservercompany.com [207.210.66.194]
27-05-2008 4:11 PM
Next logical step I guess would be for us to try connecting as you here to see if we can replicate the issue. You'd need to disconnect for 30 minutes or so though to allow me time to do this.
