Some sites not loading?
- Re: Some sites not loading?
24-08-2011 12:40 PM
I am experiencing different issues (that is to say, different sites not loading) on two different plusnet connections. Though not the same sites on both connections. This has been going on for the past few weeks I think (it's taken me a while to really notice this as a problem).
I've tried various DNS settings (Plusnets, My own and Googles Public DNS) but the only way I can get these sites to load is via a VPN/Proxy.
A couple of sites that I can remember include mozilla add ons ( https://addons.mozilla.org ), the adobe flash download site, and Ukeulele Hunt ( ukulelehunt.com ) which are currently working on my plusnet work connection but weren't working at home for the past few days.
24-08-2011 12:49 PM
We need some further information to diagnose this type of issue. As soon as you are unable to load a particular page you should open a command prompt and try (e.g. www.website.com not loading):
ping www.website.com
and:
tracert www.website.com
And post the results. This should point us in the direction of the cause.
24-08-2011 1:04 PM
24-08-2011 2:54 PM
- Sites that use https
- Sites that use flash
- Sites that use java
In some instances the problem can be specific to a particular web browser so it is worth trying an alternate browser to see if that makes any difference. And of course, the problem might be associated with none of the above
24-08-2011 3:05 PM
Quote from: Alex Hi z0mb13e,
and:
I did tracert a few sites and some timed out, some didn't. Hence me trying other DNS server.
I will post some results when I find a site that isn't loading as expected.
24-08-2011 3:06 PM
Quote from: sjrinfroyle My first guess would be an MTU issue. What modem router do you have?
Could be...
I am using a zoom bridge coupled with an Asus RT13
24-08-2011 3:08 PM
Quote from: ReedRichards In my travels I have encountered web browser problems with:
I did try the failing sites in IE after it failed in FF. The issue doesn't appear to be browser related as the sites load perfectly well if I establish a VPN to another country...
24-08-2011 3:23 PM
Quote from: z0mb13e
Could be...
Or a zyxel P661-H (I think) in bridge mode connected to a smoothwall box...
24-08-2011 10:49 PM
Tracing route to ukulelehunt.com [96.30.58.84]
over a maximum of 30 hops:
1 2 ms 1 ms 1 ms 192.168.0.1
2 64 ms 41 ms 46 ms lo0-homesurf.ptn-ag01.plus.net [195.166.128.124]
3 33 ms 32 ms 32 ms gi2-6-605.ptn-gw01.plus.net [84.92.3.17]
4 32 ms 31 ms 32 ms po6.thn-gw1.plus.net [212.159.1.136]
5 32 ms 32 ms 32 ms po4.thn-gw2.plus.net [212.159.1.135]
6 32 ms 32 ms 32 ms te-3-4.car5.London1.Level3.net [217.163.45.181]
7 45 ms 32 ms 34 ms ae-34-52.ebr2.London1.Level3.net [4.69.139.97]
8 101 ms 101 ms 102 ms ae-42-42.ebr1.NewYork1.Level3.net [4.69.137.70]
9 101 ms 101 ms 101 ms ae-4-4.ebr1.NewYork2.Level3.net [4.69.141.18]
10 101 ms 101 ms 102 ms ae-1-100.ebr2.NewYork2.Level3.net [4.69.135.254]
11 122 ms 122 ms 122 ms ae-2-2.ebr1.Chicago1.Level3.net [4.69.132.65]
12 121 ms 122 ms 123 ms ae-6-6.ebr1.Chicago2.Level3.net [4.69.140.190]
13 122 ms 122 ms 122 ms ae-1-51.edge4.Chicago2.Level3.net [4.69.138.135]
14 121 ms 121 ms 121 ms WiredTree.edge4.Chicago2.Level3.net [4.28.68.14]
15 124 ms 123 ms 124 ms vl38.dsw3.chi2.wiredtree.com [173.199.135.230]
16 123 ms 122 ms 122 ms 96.30.56.25
17 121 ms 122 ms 122 ms vps.ukulelehunt.com [96.30.58.84]
Trace complete.
I keep seeing sites getting stuck loading from addthis.com, specifically s7.addthis.com
Tracing route to e2943.c.akamaiedge.net [92.123.168.20]
2 34 ms 33 ms 33 ms lo0-homesurf.ptn-ag01.plus.net [195.166.128.124]
3 32 ms 32 ms 48 ms gi2-6-605.ptn-gw01.plus.net [84.92.3.17]
4 33 ms 35 ms 31 ms t2a1-ge2-0-0.uk-lon1.eu.bt.net [166.49.211.45]
5 137 ms 77 ms 32 ms 166-49-135-22.eu.bt.net [166.49.135.22]
6 32 ms 32 ms 32 ms gi2-6.lonse1.London.opentransit.net [193.251.150
.225]
7 36 ms 35 ms 35 ms tengige0-15-0-2.lontr1.London.opentransit.net [1
93.251.129.69]
8 * * * Request timed out.
9 40 ms 40 ms 40 ms xe-6-1-3-0.auvtr3.Aubervilliers.opentransit.net
[193.251.129.121]
10 40 ms 39 ms 41 ms a92-123-168-20.deploy.akamaitechnologies.com [92
.123.168.20]
Trace complete.
tracert addons.mozilla.com
Tracing route to redirect-com.glb.mozilla.com [63.245.209.37]
1 1 ms 1 ms 1 ms 192.168.0.1
2 35 ms 32 ms 31 ms lo0-homesurf.ptn-ag01.plus.net [195.166.128.124]
3 34 ms 32 ms 31 ms gi2-6-605.ptn-gw01.plus.net [84.92.3.17]
4 36 ms 32 ms 34 ms t2a1-ge2-0-0.uk-lon1.eu.bt.net [166.49.211.45]
5 34 ms 31 ms 32 ms ge-2-1-0.mpr1.lhr2.uk.above.net [195.66.224.76]
6 32 ms 31 ms 33 ms ge-2-1-0.mpr1.lhr2.uk.above.net [64.125.28.141]
7 106 ms 108 ms 105 ms so-1-1-0.mpr1.dca2.us.above.net [64.125.31.186]
8 114 ms 105 ms 105 ms xe-0-3-0.cr1.dca2.us.above.net [64.125.29.17]
9 139 ms 138 ms 138 ms xe-1-3-0.cr1.iah1.us.above.net [64.125.31.213]
10 171 ms 169 ms 178 ms xe-1-3-0.cr1.lax112.us.above.net [64.125.26.122]
11 189 ms 170 ms 169 ms xe-2-1-0.cr1.sjc2.us.above.net [64.125.24.18]
12 171 ms 170 ms 170 ms 64.125.28.17.available.above.net [64.125.28.17]
13 171 ms 171 ms 170 ms 64.125.189.26
14 171 ms 171 ms 171 ms te-8-2.core2.sjc.mozilla.net [63.245.208.98]
15 172 ms 171 ms 171 ms static-redir-com.nslb.sj.mozilla.com [63.245.209
.37]
Trace complete.
25-08-2011 7:25 AM
25-08-2011 8:58 AM
Quote from: ReedRichards A while ago, maybe a month or two, there was someone who posted on this forum who could not access the internet at all except via the VPN to his work network. I cannot remember how this problem was resolved, router issue maybe?
That is always a possiblity. My home router setup is new as my old setup was getting flaky.
The current setup at work has been in place for over a year and has been very stable. That said the sites that weren't loading at work are now starting to work again, albeit with long load times. So I will ignore that for the time being and just assume that was a coincidence.
So if it is my router, why do these sites load over VPN but not without? What settings should I be looking at?
If I remember correctly the MTU is set to 1492.
I also had fun and games getting the bridge to connect (see http://community.plus.net/forum/index.php/topic,97742.16.html) where I had to set the UBR with PCR (Unspecified Bit Rate with Peak Cell Rate) set at 1143.
Everything was working well initially... that said I had to reinstall the main laptop recently as it was also pretty flaky... I really need to eliminate the laptop as the culprit...
25-08-2011 10:38 AM
