Some help please - order tracker
- Some help please - order tracker
20-04-2009 10:20 PM
Hey, ive just ordered unlimited broadband with plus net (migrating from aol). And basically on the order tracker its on the "checking your details" step - and it says:
"Sorry - we found a problem whilst checking your details.
Our support team will now make more checks and email you as soon as possible. "
So i phoned up and the person on the phone said everything is fine and my broadband will be activated on the 27th.
So just wondering why it still says that in the order tracker? is it an error and will update soon enough and il receive an email? or is there still a problem. Bit confused!
Message 1 of 6
(1,095 Views)
5 REPLIES 5
Re: Some help please - order tracker
20-04-2009 11:56 PM
Hi KaotiK,
I'll check it in the morning, if it hasn't updated I'll make sure it's in the correct state for you.
Message 2 of 6
(566 Views)
21-04-2009 9:07 AM
That's sorted that, it should now show that the order is processing.
Message 3 of 6
(566 Views)
21-04-2009 10:56 AM
Thanks for that
Message 4 of 6
(566 Views)
21-04-2009 11:11 AM
Just one more question please. My router's MTU size is currently set to 1450 (because AOL had told me to change it to that a while back) just wondering what it should be for plusnet? or isit fine at 1450?
Message 5 of 6
(566 Views)
21-04-2009 11:22 AM
The only thing that may make a significant difference is if the MTU on your PC is less than the MTU on the router.
As I've never seen a router MTU being bigger than the PC MTU cause problems if MTU path discovery is turned on on the PC (as it should be by default), I tend to say make the router MTU the maximum possible (1500) and forget it, but if all is well with your existing settings then you can leave well alone.
Message 6 of 6
(566 Views)
