So much for being fixed
xxandy77xx
not to good  through the day  bad through the evening
5.15pm  7.00pm
20.20pm
23 REPLIES 23
xxandy77xx
Re: So much for being fixed
21.0021.30
19th mar.
Pettitto
Fixes: 5
I can see that you've added details of this issue on your Fault Ticket which will be picked up ASAP.
xxandy77xx
Yeah see what they can find if anything, if it is fixed then i have no idea what`s wrong
20th mar.
xxandy77xx
xxandy77xx
19thMar
xxandy77xx
20th Mar
xxandy77xx
not getting any better
xxandy77xx
xxandy77xx
Reply from ticket no fault found,  so was told must be issue with the technicolor router and not with the service itself, because your Openreach modem is reporting a clear speed of 73.3mbps down and 20.0mbps up .  Ok as i`am not using the bt  modem or the tg582  (using the tg589vn 3) , so i phoned up and  now sending engineer for contention issues.
xxandy77xx
xxandy77xx
AndyH
Which exchange are you on?
xxandy77xx
Hi andy
My exchange is meadowfield (NEMEA)
Sun
xxandy77xx
