So I was advised to join the 21CN trial.........
- So I was advised to join the 21CN trial.........
- « Previous
- 1
- 2
- Next »
Re: So I was advised to join the 21CN trial.........
21-04-2009 10:30 AM
I'm going to post everything that you need to know later today but i'm holding off for a bit as i'm logging things with http://faults.plus.net too. They need 3 speedtests and I'm going to try do that too. I'll post everything later as I said and we can see where we go from there.
P.S. Extension wise I don't have anything else connected to the phone line. No sky box filter or nothing. Just my phone filter thingy.
Message 16 of 18
(248 Views)
21-04-2009 3:55 PM
Here's today's joyful results. (Been on the test socket since last night with this so not touched anything) I will alter my post to show line stats with the normal socket plugged in.
10:15am
System Up Time 11:55:44
Port Status TxPkts RxPkts Collisions Tx B/s Rx B/s Up Time
WAN PPPoE 26707 32109 0 698 3466 02:17:39
LAN 10M/100M 490440 264229 0 2187 780 11:55:39
WLAN 11M/54M 58 37 0 0 0 11:55:30
ADSL Link Downstream Upstream
Connection Speed 2400 kbps 448 kbps
Line Attenuation 61 db 15.5 db
Noise Margin 6 db 17 db
Test1 comprises of Best Effort Test: -provides background information.
Your DSL connection rate: 2400 kbps(DOWN-STREAM), 448 kbps(UP-STREAM)
IP profile for your line is - 2000 kbps
Actual IP throughput achieved during the test was - 111 kbps
This test was not conclusive and further testing is required.
Please wait whilst you are redirected to undertake a second test.
You now have two choices-
If you wish to carry out further tests and you are competent to make changes to your ADSL system configuration, then please click on 'Continue' button.
If not, please close the window using 'Exit' button and contact your ISP for further assistance with these results.
12:45pm
Actual IP throughput achieved during the test was - 468 kbps
If you wish to discuss these results please contact your ISP.
If you are experiencing problems with specific applications, servers or websites please contact your ISP for assistance.
Your test has completed please close this window to exit the performance tester.
System Up Time 14:21:08
WAN PPPoE 94998 126921 0 1030 7826 04:43:03
LAN 10M/100M 582959 333660 0 3859 910 14:21:03
WLAN 11M/54M 58 37 0 0 0 14:20:54
3:50pm
Actual IP throughput achieved during the test was - 87 kbps
System Up Time 17:25:43
WAN PPPoE 179461 238195 0 1104 9030 07:47:38
LAN 10M/100M 691379 419630 0 5120 998 17:25:38
WLAN 11M/54M 58 37 0 0 0 17:25:29
10:15am
12:45pm
3:50pm
Message 17 of 18
(248 Views)
21-04-2009 4:07 PM
1 reboot with normal line thingy in later and:
System Up Time 00:01:12
WAN PPPoE 101 95 0 264 1076 00:00:30
LAN 10M/100M 380 621 0 2349 1188 00:01:07
WLAN 11M/54M 0 0 0 0 0 00:00:58
Connection Speed 2464 kbps 448 kbps
Noise Margin 6 db 18 db
Message 18 of 18
(248 Views)
- « Previous
- 1
- 2
- Next »
