So I was advised to join the 21CN trial.........
- So I was advised to join the 21CN trial.........
20-04-2009 1:16 PM
Re: So I was advised to join the 21CN trial.........
20-04-2009 1:32 PM
Post your router stats (sync, noise margin and attenuation) (http://www.kitz.co.uk/adsl/frogstats.php gives instructions for many routers)
Post the results from http://www.speedtester.bt.com/
Tell us what https://portal.plus.net/my.html?action=stable_rate says for your current line speed.
Also describe your setup (how many telephone sockets, what other equipment (e.g. answer phones, Sky boxes, alarms etc) you also have), where the router is plugged in)
20-04-2009 2:08 PM
System Up Time 41:54:02
Port Status TxPkts RxPkts Collisions Tx B/s Rx B/s Up Time
WAN PPPoA 474046 601100 0 848 5459 25:00:00
LAN 10M/100M 614259 519448 0 3155 675 41:53:58
WLAN 11M/54M 186575 110561 0 1559 61 41:53:48
ADSL Link Downstream Upstream
Connection Speed 1120 kbps 448 kbps
Line Attenuation 59 db 15.5 db
Noise Margin 13 db 16 db
Speedtester from BT:
Test1 comprises of Best Effort Test: -provides background information.
Your DSL connection rate: 1120 kbps(DOWN-STREAM), 448 kbps(UP-STREAM)
IP profile for your line is - 750 kbps
Actual IP throughput achieved during the test was - 223 kbps
If you wish to discuss these results please contact your ISP.
If you are experiencing problems with specific applications, servers or websites please contact your ISP for assistance.
Your test has completed please close this window to exit the performance tester.
(got more of them from yesterday I can post)
portal says:
Telephone number:
(edited it out)
Phone exchange:
CUMBERNAULD
Estimated line speed:
1.0 Mbps - Checked on 2009-03-24 16:21:32
Current line speed:
750
Your estimated line speed
If we've done a line check for you, we provide an estimate of the broadband speed that your line should support.
Please see above for the 'Estimate line speed'.
If we're unable to provide a line check, we give you the option of continuing without a speed estimate, in which case you'd see the Speed Estimate as "Opted out".
Phone's connected to the main socket with an Iplate fitted. It's also a NETGEAR DG834GV3 Router i'm using although i've requested that I get a new 1 from plusnet.
20-04-2009 3:36 PM
Can you try plugging the filter and router in to the test socket (without putting a phone in the other socket on the filter) and post the bottom half of the router statistics page where it gives the Connection Speed, Line Attenuation and noise margin. These are the only thing we need to look at at the moment. The 13db noise margin suggests where may be something giving some interference on the line.
When you use the phone is there any background noise? You can check this out using the BT quiet line test - dial 17070 and use option 2. If there is any noise try it again with the phone plugged in to the test socket and if you can try with another handset (wired is better than cordless for this check).
You haven't said if you have any other extensions and what other equipment you have plugged in to any phone sockets.
The test socket is inside the master socket:
20-04-2009 6:39 PM
I put in 59DB on the kitz thingy and I got:
dslMax 2752Kbps (IP Profile 2000kbps)
adsl2+ (21CN) 2944kbps (IP Profile 2500kbps)
adsl2+ (LLU) 2944kbps (Throughput 2605kbps)
Forgot to add when i'm testing with the test socket should I have my iplate plugged in? or have that totally out the way?
20-04-2009 7:15 PM
If the sync looks better when using the test socket it is a case of carefully putting this back one by one to see what causes the problems.
20-04-2009 7:45 PM
Quote from: nutter123 Basically I've been suffering from speed problems most of the weekend and had a dramatic fall from when I first joined plusnet from 180K download speeds to just about 80 odds. I was advised that I should join 21CN trial as there's nothing found that's wrong with my line apparently and my speeds aren't too great. Was I even wise to apply in the first place? My other option was to raise a fault but for cert I know nothing would be found wrong and I would be liable probably for a BT engineer charge (which I simply can't afford)
I was getting terrible speeds on ADSL and have just been moved onto ADSL2+. Whilst I'm not getting the advertised speeds of 'up to' 24 MB (I share my bathroom with the exchange it's that close) I am getting 6MB at most times of the day. Compare that to 1/2 Meg on ADSL and it's looking pretty good. (BT also confirmed nothing wrong with my line)
So in short, look forward to a faster service (Hopefully :D)
Matt
20-04-2009 8:02 PM
adie:quote
20-04-2009 8:21 PM
(Now in the test socket)
Router stats:
System Up Time 00:00:36
WAN PPPoA 120 88 0 1354 2498 00:00:11
LAN 10M/100M 299 482 0 3291 2260 00:00:32
WLAN 11M/54M 0 0 0 0 0 00:00:21
Connection Speed 2368 kbps 448 kbps
Line Attenuation 61 db 15.5 db
Noise Margin 1 db 18 db
Your DSL connection rate: 2368 kbps(DOWN-STREAM), 448 kbps(UP-STREAM)
Actual IP throughput achieved during the test was - 34 kbps
This test was not conclusive and further testing is required.
Please wait whilst you are redirected to undertake a second test.
You now have two choices-
If you wish to carry out further tests and you are competent to make changes to your ADSL system configuration, then please click on 'Continue' button.
If not, please close the window using 'Exit' button and contact your ISP for further assistance with these results.
(I must admit that looks cack) although the tester WAS busy
http://www.speedtest.net/result/456453674.png
That line test thingy....I didn't hear anything. Whirring again although the more I think about it that was more than likely my fan on my PC.
20-04-2009 8:35 PM
Quote from: nutter123 ADSL Link Downstream Upstream
Ouch! That noise margin is too low - the router is struggling to hold sync at that speed - pretty soon the number of errors it gets will cause it to resync at a lower speed which will give a higher margin.
What we've done so far is to demonstrate that internal telephone wiring and other equipment is the cause of your problem.
A couple of things to confirm:
1. You are using standard length cables (a filter with about a 6" lead and a a filter to router lead of about 6 ft with no other extension leads).
2. The router isn't near any electrical equipment (at least 3 ft separation) including your PC (noisy PC power supplies have been known to cause problems).
20-04-2009 8:41 PM
The PC itself is only a few months old. No idea of distance and whatever. I know PC'S on a table if it helps! God i've got no idea what else I can do or if it was even wise to apply for the 21CN. Would be wasting my time raising a fault I suspect...........
20-04-2009 8:50 PM
I'd like to see where the speed stabilises in the test socket before moving on. Can you turn the router off, wait a few minutes and then power it up using the test socket again. I'd like to see it syncing with a noise margin of at least 6 and see what the speed is then.
20-04-2009 9:52 PM
Your DSL connection rate: 2464 kbps(DOWN-STREAM), 448 kbps(UP-STREAM)
Actual IP throughput achieved during the test was - 119 kbps
System Up Time 00:04:34
WAN PPPoA 803 928 0 1037 4805 00:02:39
LAN 10M/100M 1959 2228 0 4541 1343 00:04:31
WLAN 11M/54M 0 0 0 0 0 00:04:20
Connection Speed 2464 kbps 448 kbps
Noise Margin 5 db 18 db
http://www.speedtest.net/result/456519584.png
Last I'll do for tonight. I'm convinced that the BT speedtester is playing silly buggers with me but what do I know.
20-04-2009 10:17 PM
20-04-2009 10:24 PM
That will give us a good comparison.
Forget all the other tests - this is all you need to look at at the moment. I wouldn't change the firmware just yet - we don't want to confuse things by making too many changes at the same time as we might not be able to tell what made a difference.
When you started you had
You still haven't answered how many phone extensions you have. Can you put the front back on the master socket, plug in the filter and router only (definitely no phone handset), make sure there is absolutely nothing plugged in to any other telephone socket anywhere else in the house and then get the above stats again.
Depending on what they show will determine the next step.
