Snr
- Snr
Snr
14-05-2008 12:34 PM
Since Bt fixed a fault on my line some 3 odd weeks ago, line has been really stable and the only times the router has been off is when i have had to turn it off to do something to my electrics.
Its been syncing somewhere in the region of 6mb with the snr running between 11.5- 13.5.
Not long ago i had a disconnect and the router has resynced at
Rate (Kbps): 8032 448
SNR Margin (dB): 5.4 19.0
Attenuation (dB): 38.0 21.5
Output Power (dBm): 11.8 19.8 .
Just noticed the snr is a lot lower, anything to worry about or not ?
Chris.
Chris.
Message 1 of 3
(784 Views)
2 REPLIES 2
Re: SNR
14-05-2008 12:40 PM
No, that's good, 6dB is the "normal" target level.
Message 2 of 3
(240 Views)
Re: SNR
14-05-2008 12:43 PM
Ooh nice :).
Message 3 of 3
(240 Views)
