Smart tv samsung and Internet
- Re: Smart tv samsung and Internet
16-01-2013 8:08 PM
Hi have just bought samsung smart tv, connecting through thomson wireless. All was ok at first but now although it finds router and sometimes says connected, every time I go into the web browser I get the message to say network not connected, I go through again and sometimes get connected to network but not Internet other times connected to Internet . Any advice please
Message 1 of 4
(1,502 Views)
3 REPLIES 3
16-01-2013 9:50 PM
I think that you'll get detailed assistance from Samsung, rather than this forum.
Message 2 of 4
(512 Views)
16-01-2013 11:36 PM
I have a Samsung TV billed as "smart" but a couple of years old now so maybe not so smart as the current ones. This came without a built-in wireless adaptor so I bought one that was supposed to be compatible but never got it to work properly. It would connect and work when I set it up but all the settings were lost each time I switched off the TV. More recently I have used a wireless range extender with an Ethernet output http://www.amazon.co.uk/Netgear-WN3000RP-Universal-Range-Extender/dp/B0055Y6PUA/ref=sr_1_1?ie=UTF8&q... which I connect to the TV.
On the other hand, if your Thomson router is a few years old it might be one that needs a firmware upgrade to overcome some wireless problems. Which model do you have?
Message 3 of 4
(512 Views)
17-01-2013 10:42 AM
Message 4 of 4
(512 Views)
