Slowing down.
- Slowing down.
Slowing down.
08-01-2009 8:28 PM
Re: Slowing down.
08-01-2009 8:30 PM
Re: Slowing down.
08-01-2009 8:40 PM
07/01/09 dsl connection rate 6208 kbps
upstream 448 kbps
Actual throughput achieved 4566 kbps
08/01/09 dsl 6176 kbps
upstream 448 kbps
Actual 4016 kbps
Re: Slowing down.
08-01-2009 8:46 PM
Re: Slowing down.
08-01-2009 10:28 PM
Re: Slowing down.
09-01-2009 9:20 AM
As already suggested if you post your router ADSL stats (reply #1) and PN profile from the member centre (reply #3) we can do a better analysis.
Re: Slowing down.
13-01-2009 4:01 PM
Many Thanks.
Re: Slowing down.
13-01-2009 5:43 PM
The text at the top of this Kitz website page explains what router stats are (sync/connection speed, attenuation and noise margin) and further down the page hopefully you will find information on how to obtain these for your router. As you will see the procedure differs between routers so there is no universal answer to your question. It would help if you mentioned which router you are using and did you use a different one in the early days when you had higher download speeds?
Both the downstream and upstream stats are of interest.
What operating system (version of Windows) do you have on your PC?
Re: Slowing down.
13-01-2009 8:49 PM
As of late i have found the speed result to be very hit and miss most tests i do will come back with a 3 figure speed result most come back around the 200-300kbps mark. so i just dismiss these as being bt's normall rubish service as normal.
I only use the bt speed test to see what bt have my line profiled at.
Try using the http://www.mybroadbandspeed.co.uk/the one on the plusnet member centre and also http://www.speedtest.net/ after. This will tell you if bt's tester is lying.
edit= just done 3 speed tests back to back my broadband 1st speednet 2nd and then bt's and guess what as predicted bt came back 177kbps
Re: Slowing down.
13-01-2009 10:41 PM
Ideas anyone
Re: Slowing down.
13-01-2009 11:02 PM
Analysing ADSL router stats is initially far more important with these problems than speed test results.
If I had to take a wild guess however, I'd say your router was the problem.
Re: Slowing down.
14-01-2009 7:22 PM
Many thanks
Longdriver.
Re: Slowing down.
14-01-2009 8:22 PM
Re: Slowing down.
16-01-2009 7:35 PM
longdriver.
Re: Slowing down.
16-01-2009 8:24 PM
but to answer your question leaving router on is fine and is in most cases the norm but most people will do a resync every few weeks
