Slower speed
greshoff
Slower speed
I had to reset my router a couple of times while trying to set up a repeater. Prior to doing this my speed was a steady 17Mbps after resetting the router my speeds are now 15Mbps. Would the router reset account for my speed loss?
1 REPLY
Fixes: 78
Re: Slower speed
Hi, before running some diagnostics I expected to see that DLM had pushed the profile down but it hasn't.
Sorry to cover the obvious things but are you connected over WiFi or ethernet and have you tried connecting to the test socket?
 Adam Walker
