SlowSpeed
- SlowSpeed
SlowSpeed
28-12-2011 10:31 AM
Morning,
Could you please check your inhouse/exchange settings for my account, as I am having serious speed issues since moving to Plusnet. As you can see from the readings below, I have had good speed, then it seems to get throttled back...
Dec 1, 09:43 1875 kbps (234kB/s) 379 kbps (47.4kB/s) Share
Nov 30, 19:56 13698 kbps (1.71MB/s) 381 kbps (47.6kB/s) Share
Nov 30, 17:57 13445 kbps (1.68MB/s) 381 kbps (47.6kB/s) Share
Then , after speaking to one of your technical team the situation improved for a couple of days...
Dec 21, 09:09 1875 kbps (234kB/s) 373 kbps (46.6kB/s) Share
Dec 20, 08:34 13402 kbps (1.68MB/s) 378 kbps (47.3kB/s) Share
Dec 19, 09:19 13009 kbps (1.63MB/s) 380 kbps (47.5kB/s) Share
At this address, my previous ISP was providing me with 6+mbps consistently for three years, and I feel that doing checks my end is pointless, because everything is exactly the same. I am starting to feel I have made a big mistake moving to Plusnet and need to have my speed issues resolved very quickly otherwise i will be moving on to another ISP.
Speed this morning...
Today 09:00 1883 kbps (235kB/s) 378 kbps (47.3kB/s) Share
Regards-Vincent
jim:red All caps changed in title as per Forum Rules mod:end
Regards-Vincent
Message 1 of 5
(1,075 Views)
4 REPLIES 4
Re: SlowSpeed
28-12-2011 2:26 PM
HI vlbvlb,
I've changed the profile on our side to match the 16200 BT IP profile, you should see the increase in the next 15 minutes.
Jojo
Jojo
Message 2 of 5
(490 Views)
Re: SlowSpeed
28-12-2011 2:45 PM
Today 14:38 13337 kbps (1.67MB/s) 380 kbps (47.5kB/s) Share
Jojo, Many thanks, as you can see, back up to speed. feel a little bit guilty with the initial threatening tone. One of the reasons I moved to Plusnet is the openness and good communication lines that are provided, and they work very well.
Regards-Vincent
Message 3 of 5
(490 Views)
Re: SlowSpeed
28-12-2011 2:51 PM
Hi Vincent,
I think one of the reasons you were having trouble is that the circuit identifier we use to update your profile had changed but not updated on our system. Because of this the profile wasn't updated correctly. I've now rectified that so it shouldn't happen again.
Jojo
Jojo
Message 4 of 5
(490 Views)
Re: SlowSpeed
31-12-2011 11:35 AM
Jojo,
Thanks for the info, and , pleased to say that speed is still good after three days...many thanks.
Happy New Year- Vincent
Message 5 of 5
(490 Views)
