Slow wireless speed on fibre
- Slow wireless speed on fibre
10-12-2012 1:54 PM
I've just upgraded to fibre (mainly for the download limit), but can't get above 35Mb in wireless - I get 75Mb on wired.
Is there anything on the router I need to do to increase the speed?
My new laptop says it's an "n" router, like the router.
Nick
Nick
Message 1 of 4
(936 Views)
3 REPLIES 3
Re: Slow wireless speed on fibre
10-12-2012 3:10 PM
You might notice from other similar threads such as this one: http://community.plus.net/forum/index.php/topic,109766.0.html that wireless speeds do vary depending on the distance from the router and aren't ever likely to match speeds achieved over ethernet.
As one person suggests on the same thread wall-mounting the router may help improve signal strength.
Message 2 of 4
(452 Views)
10-12-2012 5:01 PM
Others suggest that waste bin mounting the router helps...
Message 3 of 4
(452 Views)
10-12-2012 5:48 PM
If your using the Plusnet supplied router then unplug it, throw it down the loo & treat yourself to a proper router for Xmas. I'm using an Asus RT-N56U & my wireless increased by 70%.
Message 4 of 4
(452 Views)
