Slow uploads to Skydrive
- Re: Slow uploads to Skydrive
20-06-2013 10:33 PM
I've recently moved from BT Infinity to PN and have a connection of around 68mbps down and 17mbps up which is largely the same as with Infinity. However, I find upload speeds with PN to Skydrive to be incredibly slow in comparison to Infinity. Does anyone else use Skydrive and if so do you have the same painfully slows upload speeds?
Does anyone know a way of speeding it up, if so I'd appreciate your advice.
Thanks in advance.
Thanks in advance.
Message 1 of 2
(567 Views)
1 REPLY 1
20-06-2013 11:14 PM
we use the skydrive client application and haven't noticed any particular slowness with the upload speeds, though they tend to be only a few meg at a time.
Message 2 of 2
(294 Views)
