Slow upload
- Slow upload
Slow upload
01-11-2011 10:04 PM
Router is plugged in to the main socket.
Re: Slow upload
01-11-2011 11:09 PM
Re: Slow upload
02-11-2011 8:31 AM
What I can see from work is estimated line speed of 8Mb, current speed 7.15Mb.
If there is any other info I can get remotely then I'm happy to do so
Re: Slow upload
02-11-2011 9:21 AM
can you do a wired speed test to see whether it's just the wireless upload that's affected?
Jojo
Re: Slow upload
02-11-2011 9:39 AM
Thanks for the reply
Not really (unless my PS3 can do it?)
My PC is upstairs (router downstairs) and we use an iPhone and iPad wirelessly, but mostly in the same room as the router. I play guitar and upload files to the web which can be fairly large so a 70kbps and slower upload really isn't going to help and as I said before, my iCloud back-up is failing.
Is there anything you can check before I get back tonight?
Re: Slow upload
02-11-2011 10:03 AM
Even when you get this immediate issue resolved upload speeds wireless are probably not going to be as fast as wired, so if that is important to you and a permanent wire up the stairs is not an option you could look at homeplugs.
Re: Slow upload
02-11-2011 10:38 AM
we have had an issue with wireless uploads with certain router/computer combinations. If we can confirm this then I could get you a different version router. If not, it would be another avenue of investigation and the router would make no difference.
Jojo
Re: Slow upload
02-11-2011 11:05 AM
Running a cable upstairs isn't an option, either aesthetically or practically. I can cope with slower uploads from the PC though, it's the Apple devices that need it to be better. The Apple devices will often be in the same room as the router so homeplugs may not help. As I said, I'll try and do a wired test using the PS3 as that is hardwired to the router, but it won't be using any of the normal sites, rather the inbuilt PS3 test.
The speedtests I've ran so far have been on both iPhone and iPad. I'm not expecting the Earth, but 43 kbps is worse than dial up
Re: Slow upload
02-11-2011 11:08 AM
if you can just confirm the wired result that'd be great. We could then look to get it resolved for you.
Jojo
Re: Slow upload
02-11-2011 7:09 PM
Link Information
Uptime: 0 days, 1:16:02
DSL Type: G.992.1 annex A
Channel mode: Fast
Maximum Bandwidth (Up/Down) [kbps/kbps]: 1,116 / 8,128
Bandwidth (Up/Down) [kbps/kbps]: 448 / 8,128
Data Transferred (Sent/Received) [kB/MB]: 0.00 / 69.71
Output Power (Up/Down) [dBm]: 11.5 / 19.5
Line Attenuation (Up/Down) [dB]: 15.0 / 27.5
SN Margin (Up/Down) [dB]: 25.0 / 9.0
Vendor ID (Local/Remote): TMMB / TSTC
Loss of Link (Remote): 0
FEC Errors (Up/Down): 0 / 0
CRC Errors (Up/Down): 0 / 21
HEC Errors (Up/Down): 0 / 39
Phone exchange:
Estimated line speed:
8Mb (Accurate to within +/- 1Mbit) - Checked on 2011-10-10 19:06:56
Current line speed:
7.15 Mb
Test1 comprises of Best Effort Test: -provides background information.
Download Speed
5583 Kbps
0 Kbps 7150 Kbps
Max Achievable Speed
Download speedachieved during the test was - 5583 Kbps
Additional Information:
Your DSL Connection Rate :8128 Kbps(DOWN-STREAM), 448 Kbps(UP-STREAM)
IP Profile for your line is - 7150 Kbps
Re: Slow upload
02-11-2011 7:13 PM
I restarted the router when I got home as it was still less than 100 kbps.
Re: Slow upload
02-11-2011 8:11 PM
Jojo should be able to sort this out for you tomorrow.
Re: Slow upload
02-11-2011 8:29 PM
Just ran another and it's not changed much so hopefully it was just a blip and the re-boot has helped.
Re: Slow upload
03-11-2011 10:20 AM
I'll see if I can dig out a TG585v7 for you, this will resolve that.
Jojo
Re: Slow upload
03-11-2011 10:39 AM
like I said, hopefully it was just a blip. I'll keep an eye on it over the next few days before we have to go down the next step of another router. Thanks for your help though
