Slow speeds
- Slow speeds
Re: Slow speeds
30-04-2012 6:24 PM
Re: Slow speeds
30-04-2012 6:34 PM
BTW you can post attachments eg. photos etc directly onto a post, either by using the "Reply" button just below the previous post and when the box is open you'll see + Additional Options and Attachments... below the box. Click on it and there is a box to Browse where you have the file.
If you've used Quick reply, click on Preview and the same appears below the box.
Re: Slow speeds
30-04-2012 6:46 PM
Re: Slow speeds
30-04-2012 6:57 PM
The cable going outside - does it go underground or up and overhead?
Re: Slow speeds
30-04-2012 7:09 PM
Hopefully the photos are attatched.
Re: Slow speeds
30-04-2012 7:24 PM
At the roof, is it under the eaves where it goes across overhead to a pole? Is there another junction box under the eaves? - Don't worry about going up there with ladders or anything just say if you can see one, perhaps a zoomed in picture?
The bad news is that cable coming into the porch is an old standard - not modern twisted pair, anyway let's see what else before the next move.
Re: Slow speeds
30-04-2012 7:29 PM
Re: Slow speeds
30-04-2012 7:39 PM
Does the cable from the house to the pole cross any road or footpaths?
Re: Slow speeds
30-04-2012 7:53 PM
The cable goes over our drive and next to the road in the hedgerow.
Re: Slow speeds
30-04-2012 8:14 PM
IF there is a fault on the cable to the pole, as it doesn't cross a road, you might get it repaired fairly quickly, once such a fault is proven.
Should this be the case and they come to replace it, you should politely insist they replace the old standard "drop-wire" into the porch, if they don't look as though they are going to - well ask if they are first.
In any event, if an engineer attends, you should try to persuade him to replace that drop wire - it's not twisted pair and will pick up interference.
Just to be clear on one other point, ALL the cables upto the NTE5 Master socket are BT's responsibility.
Back to internal stuff, if your ethernet cable is long enough, the best arrangement would be to have the modem/router next to the NTE5 - filter - short lead - modem/router. You can use an extension lead from the filter for the phone, but not for the router nor from the NTE5 to a filter.
Is the modem/router you are currently using, the one that was displaying drops or did they both do it? If the drops continue whilst plugged into the Test socket then try the other modem/router again. If the drops have disappeared whilst plugged into the Test socket, try replacing the Front plate and plugging into that. If the drops re-appear there is a bad connection between the Front Plate and the Test socket and BT will have to replace it - their problem.
Don't forget what I said about logging in, Disconnecting the ppp session and powering down the modem/router before disconnecting.
In view of your current sync speed, I would do it in daylight hours not after dark when noise levels are higher.
Re: Slow speeds
30-04-2012 8:47 PM
Yeah I was thinking the same with the arrangement of the router etc. We should have an ethernet cable that long. I'll do more logging off/disconnecting the router tomorrow. I haven't noticed any drops in the line since i've been plugged into the test socket so will try it again with the front on.
Thanks for all the help! Has been much appreciated.
Cheers, Phil
Re: Slow speeds
30-04-2012 9:02 PM
Let's see how things go in the Test socket for a while. If you are not getting drops at the moment and your sync speed is good (6000 kbps or so) leave the modem/router on - your profile will recover quicker. If you have a slower speed switch off tonight and resync in the morning.
Re: Slow speeds
01-05-2012 1:18 PM
If you're in the test socket and you've changed filters then maybe you are best calling you phone provider.Those drops are horrendous.
Jojo
Re: Slow speeds
01-05-2012 1:55 PM
Re: Slow speeds
01-05-2012 3:53 PM
Thanks for all the help! Will update this to inform on the situation.
