Slow speeds
- Slow speeds
Re: Slow speeds
28-10-2014 7:00 PM
Thanks for all the help.
Den.
Re: Slow speeds
28-10-2014 7:10 PM
Re: Slow speeds
28-10-2014 7:54 PM
Sorry to hear that you're seeing issues with regards to slow speeds again, understandably it may be tough to troubleshoot the connection issues from an iPad however the router stats should be insightful as Anotherone mentioned.
Your line profile is looking good at 4mbps against the estimated speeds you should be seeing which are between 1mbps and 2.5mbps and a quick line tests shows that the profiles match all the way round.
On a side note, I pre-empted the possibility of this being exchange related by checking for any issues and your exchange appears to be missing from the report. I'm not quite sure what this means with regards to it not being included but I'll check this with a few people tomorrow and see what we can find out about it. Hopefully it's exclusion will be a positive but we'll have to wait and see.
Re: Slow speeds
28-10-2014 8:04 PM
Re: Slow speeds
29-10-2014 8:09 AM
Could I also ask for my router firmware to be remotely updated also.
Thanks in advance.a
Den.
Re: Slow speeds
29-10-2014 8:15 AM
DSL Connection
Link Information
Uptime: 17 days, 16:42:27
DSL Type: ITU-T G.992.1
Bandwidth (Up/Down) [kbps/kbps]: 448 / 5.216
Data Transferred (Sent/Received) [GB/GB]: 1,99 / 1,99
Output Power (Up/Down) [dBm]: 12,3 / 19,9
Line Attenuation (Up/Down) [dB]: 27,5 / 49,0
SN Margin (Up/Down) [dB]: 20,0 / 3,8
Chipset Vendor ID (Local/Remote): BDCM / TSTC
Loss of Framing (Local/Remote): 0 / -
Loss of Signal (Local/Remote): 0 / -
Loss of Power (Local/Remote): 0 / -
Loss of Link (Remote): -
Error Seconds (Local/Remote): 2.190 / -
FEC Errors (Up/Down): 1.157 / 209.559.173
CRC Errors (Up/Down): 409 / 3.850
HEC Errors (Up/Down): -09 / 3.850 / 42.133
Re: Slow speeds
29-10-2014 9:04 AM
I'll take a closer look back through your previous stats and post back later.
Re: Slow speeds
29-10-2014 9:05 AM
Edit: if you can run the BTw Performance test (ignore the red preamble except make sure no other programs are using the Internet) and at the end of the first run, click the Further Diagnostics button, enter just your Phone number and Run the Further Diagnostics Test. Whatever you manage do NOT reboot. However I suspect the BTw Tester will not run from your iPad.
Do a Copy and Paste of the results and post here (no need to grab an image).
Re: Slow speeds
29-10-2014 9:34 AM
Estimated line speed:
Current line speed:
4 Mb
Btw performance test not supported for iPad.
Thanks.
Den.
Speedtest result
http://www.speedtest.net/my-result/i/1015517585
Re: Slow speeds
29-10-2014 9:40 AM
Re: Slow speeds
29-10-2014 9:47 AM
Speeds are generally between 1-3mb now but constantly spike during playing ps4 causing lag and server disconnections.
Den.
Re: Slow speeds
29-10-2014 9:55 AM
Forgot to mention, the PS4,is that connected wirelessly or by ethernet?
Re: Slow speeds
29-10-2014 10:13 AM
Also I need to correct myself got the router flashing light confused just to clarify .
Broadband stays green constantly (unless disconnects completely).
The rapidly flashing lights are the Internet and wifi lights (which happens randomly several times a day).
When ps4 connected with homeplugs the Ethernet and Internet lights rapidly at random times serval times a day which cause serve lag and server disconnects.
Sorry for my mistake and confusion over the router.
Thanks again.
Den.
Re: Slow speeds
29-10-2014 10:20 AM
With regards the Internet and WiFi light s flashing, they will when traffic is passing - flashing green.
If the Internet light starts going red or flashing red, then there could well be a problem with connection.
Re: Slow speeds
29-10-2014 10:35 AM
I've just updated your profile to 4.5MBps.
Are you able to PM me your current routers serial number so I can push the firmware.
Cheers,
Dan
