Slow speeds
Anotherone
Champion
Fixes: 21
Re: Slow speeds
There you go, progress Wink  When the update is all complete etc (you'll have to wait and see when) post up the new DSL Stats.
Den
Re: Slow speeds
PM sent
Thank you guys.
Den
Den
Re: Slow speeds
A big thank you guys
Now have firmware 10.2.2.B
Also new router stats.
DSL Connection
Link Information
Uptime: 0 days, 0:11:56
DSL Type: ITU-T G.992.1
Bandwidth (Up/Down) [kbps/kbps]: 448 / 5.024
Data Transferred (Sent/Received) [MB/MB]: 3,09 / 16,68
Output Power (Up/Down) [dBm]: 12,3 / 19,9
Line Attenuation (Up/Down) [dB]: 27,5 / 49,0
SN Margin (Up/Down) [dB]: 20,0 / 6,0
Chipset Vendor ID (Local/Remote): BDCM / TSTC
Loss of Framing (Local/Remote): 0 / -
Loss of Signal (Local/Remote): 0 / -
Loss of Power (Local/Remote): 0 / -
Loss of Link (Remote): -
Error Seconds (Local/Remote): 0 / -
FEC Errors (Up/Down): 0 / 7.304
CRC Errors (Up/Down): 0 / 0
HEC Errors (Up/Down): - / 0
Thanks again.
Den.
Anotherone
Champion
Fixes: 21
Re: Slow speeds
Actually that's looking somewhat better, mainly because of the speed you are getting with the 6dB margin. BUT irritatingly you are 96kbps short of the 4.5Mbps profile.
Certainly don't do anything anytime between an hour before sunset and an hour after sunrise, but in daylight hours (around middayish is often best) - IF the SNRM is steady and better than say 6.4dB it would be worth a resync to see if you can get the speed to 5120 or a touch higher. There's not much point in it being much higher on 20CN, it would have to go to 5696 to get a 5Mbps profile and I would say the SNRM would drop too low at night that your line may get unstable.
If you see this post this evening, post the current stats so we get an idea of what you line is like after dark.
Den
Re: Slow speeds
Router for this morning, will copy and paste same tonight.
DSL Connection
Link Information
Uptime: 0 days, 15:38:03
Bandwidth (Up/Down) [kbps/kbps]: 448 / 4.992
Data Transferred (Sent/Received) [MB/GB]: 199,22 / 2,08
SN Margin (Up/Down) [dB]: 20,0 / 5,9
Error Seconds (Local/Remote): 45 / -
FEC Errors (Up/Down): 7 / 462.818
CRC Errors (Up/Down): 4 / 88
HEC Errors (Up/Down): - / 1.089
Anotherone
Champion
Fixes: 21
Re: Slow speeds
Sync speed is a bit lower than last time. Did you reboot sometime around 5.20 pm yesterday or possibly have a power dip?
jelv
Fixes: 10
Re: Slow speeds
I'd definitely recommend doing as Anotherone suggested and check the downstream SN margin around midday. If it's 6.4dB or better try a resync.
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
Den
Re: Slow speeds
New router stats also there must have been a power cut as cooker clock was flashing.
DSL Connection
Link Information
Uptime: 0 days, 19:10:30
Data Transferred (Sent/Received) [MB/GB]: 236,15 / 2,33
Error Seconds (Local/Remote): 49 / -
FEC Errors (Up/Down): 17 / 635.441
CRC Errors (Up/Down): 5 / 93
HEC Errors (Up/Down): - / 1.132
Thanks.
Den.
Anotherone
Champion
Fixes: 21
Re: Slow speeds
Well at present, the error rate looks pretty good, but it does look as though the SNRM is today rock solid at around 5.9dB so a re-sync would be pointless.
All in all things look promising.
Den
Re: Slow speeds
Router stats posted again, how does the sn margin 5.9bd work the lower the number the better or vice versa?
Sorry still learning
Physical Connectivity OK
DSL Connection
Link Information
Uptime: 1 day, 2:02:56
Data Transferred (Sent/Received) [MB/GB]: 324,41 / 2,87
SN Margin (Up/Down) [dB]: 20,0 / 5,6
Error Seconds (Local/Remote): 55 / -
FEC Errors (Up/Down): 35 / 2.786.640
CRC Errors (Up/Down): 7 / 102
Den.
jelv
Fixes: 10
Re: Slow speeds
As the sync speed increases the noise margin decreases. You also have the variability as you've seen.
When the modem syncs with the exchange they negotiate the fastest sync speed possible until the noise margin is at the target (6dB in your case). If you were to resync now the sync speed would be slower with the margin back at 6dB, but during the day tomorrow you would see it rise well above 6. That's why we advise resyncing during the day when background interference is lowest as that gives the best sync speed.
Den
Re: Slow speeds
Great jelve nicely explained.
Thanks.
Den.
Anotherone
Champion
Fixes: 21
Re: Slow speeds
Whether it will rise above 6 today (or anyday) will depend very much on general atmospheric conditions such that noise across the spectrum would need to be low. You may also get a small amount of cross-talk from other users on your DP and if any of them happen to turn off their modem/routers you may see the SNRM rise. You can sometimes see a similar situation with electrical/electronic equipment that has noisy power supplies.
