Slow speeds
jelv
Fixes: 10
Re: Slow speeds
Quote from: Den
Your DSL Connection Rate :5.66 Mbps(DOWN-STREAM), 0.45 Mbps(UP-STREAM)
Quote from: Den
Your DSL Connection Rate :4.74 Mbps(DOWN-STREAM), 0.45 Mbps(UP-STREAM)
Between the last two sets of stats you've posted your sync speed with the exchange has changed. That can only happen if the router loses connection with the exchange and it has to re-establish synchronisation. Did you power off or reboot the router between?
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
jelv
Fixes: 10
Re: Slow speeds
Quote from: Den
Also downloaded routerstats but don't seem to be working even though I followed the instructions whenever I press noise margin or download the graph just stays on 0 ?
In the RouterStats configuration have you entered the username ('admin') and the password which is on the card that came with the router?
Is the run button with the green arrow depressed.
Where in Purleigh are you? There's another Plusnet user on your exchange who's watching this topic - he might be able to give you a hand if we can't get this sorted.
(BTW My aunt used to live in Stow Maries so I'm not totally unfamiliar with the area)
Den
Re: Slow speeds
Hello Jelv,
Defo didn't power off the router, but the router every now and again does disconnect Sometimes during late night I have noticed, but havn't noticed whether it as disconnected the last couple of day but wouldn't be surprised if it has.
Done as instructed with the router stat but I just get a straight blue line on 0 the graph does not go up or down with the noise and also dload/upload ratio buttons pressed?
Yes I live Stow Maries for about 13 years.
Den.
jelv
Fixes: 10
Re: Slow speeds
It's the disconnections that will be causing your slower speeds - you need to concentrate on solving that first. Once that is sorted better speeds should follow after a few days.
You can tell if it has disconnected and when by looking at the up time in the router stats:
Quote from: Den
Uptime:0 days, 0:02:19
DSL Type:ITU-T G.992.1
Den
Re: Slow speeds
Was only on Line five minutes and disconnected?
Just done another Router check wonder what is causing the disconnectings?
DSL Connection
Link Information
Uptime:
0 days, 0:05:04
DSL Type:
ITU-T G.992.1
Bandwidth (Up/Down) [kbps/kbps]:
448 / 4.352
Data Transferred (Sent/Received) [MB/GB]:
469,20 / 1,99
Output Power (Up/Down) [dBm]:
12,3 / 19,8
Line Attenuation (Up/Down) [dB]:
27,0 / 48,0
SN Margin (Up/Down) [dB]:
20,0 / 9,
System Vendor ID (Local/Remote):
TMMB / ----
Chipset Vendor ID (Local/Remote):
BDCM / TSTC
Loss of Framing (Local/Remote):
0 / -
Loss of Signal (Local/Remote):
0 / -
Loss of Power (Local/Remote):
0 / -
Loss of Link (Remote):
Error Seconds (Local/Remote):
5.529 / -
FEC Errors (Up/Down):
0 / 155
CRC Errors (Up/Down):
0 / 0
HEC Errors (Up/Down):
- / 0 / 18
DSL Connection
Thanks.
Den.
Den
Re: Slow speeds
Another speed test not looking good.
1. Best Effort Test:  -provides background information.
Download  Speed
3.19 Mbps
0 Mbps 7.15 Mbps
Max Achievable Speed
Download speedachieved during the test was - 3.19 Mbps
For your connection, the acceptable range of speeds is 0.6 Mbps-7.15 Mbps.
Additional Information:
Your DSL Connection Rate :4.35 Mbps(DOWN-STREAM), 0.45 Mbps(UP-STREAM)
IP Profile for your line is - 3.5 Mbps
jelv
Fixes: 10
Re: Slow speeds
Don't bother running speed tests - we know they will be bad until the disconnections are sorted.
Can you describe what you have plugged in to any telephone socket anywhere in the house please.
Do you have a master telephone socket with a removable lower half? If so please connect the router to the test socket inside and see if you still get the drops.
http://www.plus.net/support/broadband/master-socket-guide.shtml#whatsTest
Den
Re: Slow speeds
Yes I have old socket which is similar done these checks before about 10 months ago my test socket isn't wired so was unable to do the test also I have no extension just the one master socket with no extension cables.
Thanks.
Den.
Den
Re: Slow speeds
Sorry oblivlously my telephone and router with filter are the only thing plugged into master socket, have also got homeplug for my ps4 which as never caused these problems before.
Thanks.
Den.
jelv
Fixes: 10
Re: Slow speeds
is there any noise on the phone line when you use it (dial17070 option 2 for the quiet line test)?
Den
Re: Slow speeds
If I push the phone firmly to my ear I can hear a very slight crackle.
Den.
jelv
Fixes: 10
Re: Slow speeds
You've done all you can - you now need to raise a fault for a dropping connection http://faults.plus.com
Den
Re: Slow speeds
Thanks to everyone that  helped try to resolve my disconnect problems will raise a fault as so as I get home.
Den
Den
Re: Slow speeds
Had this reply from the faults dept, will this greatly affect my gaming and will my speeds go back up as now only getting 2.88mb download max?
We have asked our wholesale broadband suppliers to turn interleaving on on your phone line to try and fix your current broadband problem.
Interleaving is a form of error correction that helps to improve the stability of high-speed broadband. One drawback of interleaving is that it can increase ping times, which may cause problems for online gamers.
We think that turning on interleaving may help with your connection problems. Interleaving usually takes 24 hours to turn on, but can take up to 5 days to take effect.
If interleaving solves your problem, please close this Question. If you are still seeing problems with interleaving switched on, please return this Question to us with as much detail about your problem as possible. Thank you for your time and patience.
Kind regards
Plusnet Customer Support
orbrey
Re: Slow speeds
It's an attempt to fix the fault but is by no means set in stone that you have to keep the line like that. Also if it's still dropping connection we'll still get it raised and sorted out for you. We'll try our best to get things back to how they were without interleaving etc.
