Slow speeds today.
- Slow speeds today.
Re: Slow speeds today.
08-05-2012 12:03 PM
Edit: Which London server are you using on speedtest.net? Also which Gateway are you on, is the same which ever Gateway?
08-05-2012 1:00 PM
08-05-2012 1:27 PM
I can see that they've asked you to provide some speed test results when you are having issues.
@ mike142sl
Are using a wired connection when this happens? If so make sure you try it with an ethernet cable.
Jojo
08-05-2012 1:39 PM
08-05-2012 2:30 PM
08-05-2012 2:44 PM
This one is structured communications
and namesco
@Anotherone, Unfortunately the Router I use only shows main stats and doesn't show error reports, the uptime has been from the 3rd of May as that is as far back as it goes, it doesn't give an actaul uptime date.
Here are my stats
Type Interleave Path
Status SHOWTIME
Downstream Upstream
Data rate(Kbps) 12184 1208
Noise Margin 4 5
Output power(dBm) 12 20
Attenuation(dB) 29 16
05/08/2012 14:40:00 192.168.2.2 login success
05/08/2012 14:39:55 192.168.2.2 login fail
05/08/2012 14:29:28 sending ACK to 192.168.2.2
05/08/2012 11:34:41 sending ACK to 192.168.2.2
05/08/2012 11:10:23 192.168.2.2 login success
05/08/2012 10:36:45 sending ACK to 192.168.2.2
05/08/2012 09:38:08 NTP Date/Time updated.
05/08/2012 03:38:07 NTP Date/Time updated.
05/07/2012 21:38:07 NTP Date/Time updated.
05/07/2012 21:01:22 sending ACK to 192.168.2.2
05/07/2012 15:42:03 sending ACK to 192.168.2.2
05/07/2012 15:38:07 NTP Date/Time updated.
05/07/2012 12:46:53 sending ACK to 192.168.2.2
05/07/2012 09:41:16 sending ACK to 192.168.2.2
05/07/2012 09:38:07 NTP Date/Time updated.
05/07/2012 03:38:07 NTP Date/Time updated.
05/06/2012 21:38:07 NTP Date/Time updated.
05/06/2012 19:22:21 sending ACK to 192.168.2.2
05/06/2012 17:34:48 sending ACK to 192.168.2.3
05/06/2012 17:34:47 sending OFFER to 192.168.2.3
05/06/2012 15:38:07 NTP Date/Time updated.
05/06/2012 13:22:33 sending ACK to 192.168.2.2
05/06/2012 11:27:08 sending ACK to 192.168.2.2
05/06/2012 09:38:07 NTP Date/Time updated.
05/06/2012 03:38:07 NTP Date/Time updated.
05/05/2012 23:35:56 sending ACK to 192.168.2.2
05/05/2012 21:38:07 NTP Date/Time updated.
05/05/2012 15:38:06 NTP Date/Time updated.
05/05/2012 15:11:18 sending ACK to 192.168.2.3
05/05/2012 15:11:16 sending OFFER to 192.168.2.3
05/05/2012 10:45:07 sending ACK to 192.168.2.2
05/05/2012 09:38:06 NTP Date/Time updated.
05/05/2012 03:38:06 NTP Date/Time updated.
05/04/2012 21:38:06 NTP Date/Time updated.
05/04/2012 17:42:28 sending ACK to 192.168.2.2
05/04/2012 15:38:06 NTP Date/Time updated.
05/04/2012 13:02:50 sending ACK to 192.168.2.2
05/04/2012 10:50:34 sending ACK to 192.168.2.2
05/04/2012 09:38:06 NTP Date/Time updated.
05/04/2012 03:38:06 NTP Date/Time updated.
05/03/2012 21:48:54 User from 192.168.2.2 timed out
05/03/2012 21:38:06 NTP Date/Time updated.
05/03/2012 15:38:05 NTP Date/Time updated.
This is a rolling log, when a new entry appears, the oldest entry disappears.
Heres one from France
08-05-2012 2:53 PM
08-05-2012 3:01 PM
08-05-2012 3:04 PM
I am hard wired into my PC but I have wireless on for my PS3, (my PS3 is turned off when I am gaming). Would it be worth turning wireless off on my router, as with the slow speeds being so intermittant,could someone piggy backing on my wireless cause the slow speeds ?
08-05-2012 3:13 PM
When you swap things about follow this procedure -
Login to the modem/router interface and click on the "Disconnect" button - this terminates the "ppp" session to the ISP (not sync to the exchange). Wait a good minute after the button changes to "Connect" (refresh the page to be sure).
Then power down the modem/router. Wait a good minute before unplugging the modem/router or it's filter from the line. Then swap whatever needs to be swapped.
When you power up, dependant on the modem/router and last settings, you may need to login into it and click on "Connect".
Don't do more than about 5 swaps in an hour and then leave for the rest of the day.
Edit: It will be the errors over at least an hour but ideally a little more whilst the throughput is down. Don't forget stats before, during, and after.
08-05-2012 3:19 PM
James.
08-05-2012 4:55 PM
I'm not on Fibre just standard up to 8mb. Done a speed test which produces this
Did this as well
08-05-2012 5:23 PM
As you problem has undoubtedly different complications, I suggest it may be best to start your own thread so as not to get things confused with the other existing problem.
08-05-2012 9:21 PM
08-05-2012 10:11 PM
