Slow speeds since Saturday
- Slow speeds since Saturday
Re: Slow speeds since Saturday
18-10-2010 4:57 PM
Today 16:54 4103 kbps (513kB/s) 345 kbps (43.1kB/s) Share
Today 06:40 230 kbps (28.8kB/s) 377 kbps (47.1kB/s) Share
Yesterday 18:17 359 kbps (44.9kB/s) 375 kbps (46.9kB/s) Share
Yesterday 07:40 247 kbps (30.9kB/s) 378 kbps (47.3kB/s) Share
if you remember on Friday when you told me ro rebbot my router it worked fine for several hours, I left the router switched on but when I switched my pc on the next morning the speed was down dramatically so hopefully it will stabalise better this time round
19-10-2010 6:38 AM
Today 06:29 4457 kbps (557kB/s) 376 kbps (47kB/s) Share
Yesterday 18:45 3857 kbps (482kB/s) 341 kbps (42.6kB/s) Share
Yesterday 17:24 3952 kbps (494kB/s) 273 kbps (34.1kB/s) Share
Yesterday 16:54 4103 kbps (513kB/s) 345 kbps (43.1kB/s) Share
I'm not sure what this all means regarding my initial speed faults (is the matter resolved)...could you shed any light on the matter for me
regards
Giovanni
19-10-2010 10:48 AM
Your sync rate can depend on what time you reboot but at the moment you now have 5000k profile so it has increased somewhat. If you log into your router and disconnect then reconnect you will see the difference.
Jojo
19-10-2010 6:42 PM
that my connection has settled down.
Whats the next step....can I start using my slave phone socket later in the week ?
regards
Giovanni
20-10-2010 10:58 AM
If you do move it back to the other socket and it degrades then it may point to that being the issue.
Jojo
20-10-2010 1:19 PM
Quote from: ggiannandrea profile is a lot better now and line appears to be more stable has anything been done to my line by BT at the exchange or is it because I'm still plugged into the Bt master socket
If you take a note of the router stats (sync speed, noise margin and attenuation) before you move the router and then again after you've moved the router you should be able to see if using the extension socket is causing a problem. Post them here if you need help interpreting them.
PS: One common mistake made is that if you use an extension socket for the router and you have a phone (or Sky box etc) in the master socket you still need to have them connected via a filter.
20-10-2010 4:44 PM
regards
Giovanni
20-10-2010 4:50 PM
20-10-2010 5:05 PM
Giovanni
Link Information
Uptime: 2 days, 23:56:38
DSL Type: G.992.1 annex A
Bandwidth (Up/Down) [kbps/kbps]: 448 / 5,760
Output Power (Up/Down) [dBm]: 12.0 / 19.5
Line Attenuation (Up/Down) [dB]: 17.5 / 34.0
SN Margin (Up/Down) [dB]: 26.0 / 15.5
Loss of Link (Remote): 0
FEC Errors (Up/Down): 0 / 1,336,295
CRC Errors (Up/Down): 0 / 0
HEC Errors (Up/Down):
Quote ..PS: One common mistake made is that if you use an extension socket for the router and you have a phone (or Sky box etc) in the master socket you still need to have them connected via a filter.
I've been using the same set-up since I got broadband from you...years ago nothing has changed regarding the setup and no other phones have been added or sat stuff etc.
20-10-2010 8:26 PM
The noise margin is up at 15 which is significantly reducing your sync speed. With your attenuation it should be capable of syncing at well in excess of 7000.
I don't like the look of the number of FEC errors either.
Have you tried a different filter and/or router.
20-10-2010 10:48 PM
I had this response from CS earlier this evening..
Dear Mr Giannandrea,
Thanks for your time on the phone earlier this evening.
As discussed, your connection has improved, however the upstream SNR is quite high.
Your fault has been raised to our supplier. Please note that they can take between 48-72 hours to provide a response.
regards
Giovanni
20-10-2010 11:19 PM
Quote from: ggiannandrea This is the new Thomson router supplied by yourselves
If that was a reply to me I don't work for Plusnet - I'm just another Plusnet user like you.
That response from CS is complete and utter rubbish. When your upstream is already syncing at the maximum speed allowed (448) the noise margin will be higher than normal. (I've got an excellent line and pay extra for faster upload (832). My upstream noise margin is 14 - you are syncing slower so you should expect a higher noise margin). The higher upstream noise margin just indicates that it could sync a lot faster if it was allowed.
Your downstream sync is well below what it should be and your downstream noise margin is well above the normal 9 default - that IS a concern and is indicative of some sort of problem.
Finally all the FEC errors are on the downstream and the upstream is totally clean
21-10-2010 7:23 AM
21-10-2010 9:49 AM
I hope one of the Digital Care team is going to find out who told you the rubbish about the upstream and have a quiet word with them.
22-10-2010 4:38 PM
Still got the Thomson router plugged into the BT Master test socket and these are the latest......
Latest router stats
Uptime: 0 days, 1:21:34
Bandwidth (Up/Down) [kbps/kbps]: 448 / 5,728
Output Power (Up/Down) [dBm]: 12.5 / 19.5
Line Attenuation (Up/Down) [dB]: 17.0 / 34.0
SN Margin (Up/Down) [dB]: 26.0 / 16.0
Loss of Framing (Local/Remote): 78 / 0
Loss of Signal (Local/Remote): 9 / 0
Error Seconds (Local/Remote): 8 / 0
FEC Errors (Up/Down): 0 / 79
CRC Errors (Up/Down): 0 / 3
HEC Errors (Up/Down): 0 / 2
regards
Giovanni
