Slow speeds since Saturday
- Slow speeds since Saturday
14-10-2010 4:27 PM
Today 16:17 121 kbps (15.1kB/s) 351 kbps (43.9kB/s) Share
Yesterday 19:46 244 kbps (30.5kB/s) 347 kbps (43.4kB/s) Share
Tuesday 17:13 2602 kbps (325kB/s) 372 kbps (46.5kB/s) Share
Monday 06:33 234 kbps (29.3kB/s) 369 kbps (46.1kB/s) Share
Sunday 18:03 135 kbps (16.9kB/s) 373 kbps (46.6kB/s) Share
Sunday 16:04 135 kbps (16.9kB/s) 378 kbps (47.3kB/s) Share
Sunday 16:00 140 kbps (17.5kB/s) 375 kbps (46.9kB/s) Share
Sunday 15:40 136 kbps (17kB/s) 378 kbps (47.3kB/s) Share
Sunday 12:07 126 kbps (15.8kB/s) 365 kbps (45.6kB/s) Share
Sunday 12:05 136 kbps (17kB/s) 379 kbps (47.4kB/s) Share
Sunday 11:46 141 kbps (17.6kB/s) 376 kbps (47kB/s) Share
Sunday 11:44 134 kbps (16.8kB/s) 360 kbps (45kB/s) Share
I've been on to customer support where after testing the line they said the problem lay with my Netgear DG834 router being unstable on ADSL 2+ broadband.( I also tried a ZYXELPrestige 660R-61, had the same problems) I was told by CS (Alex) that they would send out a new Thomson router and that would fix my problem., although I wonder if the problem at my exchange or line, meanwhile..I'm still waiting for the router to be delivered , anyone from CS happen to know my delivery date will be...
Re: Slow speeds since Saturday
14-10-2010 4:40 PM
Just had a quick look for you, our routers usually take 3 - 5 days to arrive, though it is marked as dispatched from our warehouse now, so you should expect it within the next two or three days
Hopefully this will fix your speed issues and you can return to your normal speeds!
It doesn't look like there is anything happening at your exchange at the moment, but a handy tool that we use to find out is:
http://usertools.plus.net/exchanges/
If you put your postcode in there you can see if there are any known and documented issues on your exchange.
14-10-2010 4:42 PM
14-10-2010 4:46 PM
15-10-2010 4:51 PM
Today 16:49 237 kbps (29.6kB/s) 360 kbps (45kB/s) Share
Today 16:03 271 kbps (33.9kB/s) 380 kbps (47.5kB/s) Share
All my faults can be found in Question #35964082
15-10-2010 5:17 PM
Your speed has now lifted to 3000, you just need to go into your router and disconnect then reconnect and you'll see the difference.
Jojo
15-10-2010 5:20 PM
Just did what you said JoJo and things are looking a lot better
15-10-2010 5:27 PM
15-10-2010 5:29 PM
15-10-2010 11:15 PM
It's always best to leave the router on all the time. I can't remember the last time I switched mine off.
Jojo
16-10-2010 7:20 AM
Today 07:23 395 kbps (49.4kB/s) 375 kbps (46.9kB/s) Share
Today 07:21 403 kbps (50.4kB/s) 372 kbps (46.5kB/s) Share
Giovanni
17-10-2010 12:28 PM
New Thomson router from Plusnet and still no luck
18-10-2010 6:29 AM
18-10-2010 9:20 AM
I'm not exactly sure what's going on here. These are the connections for the last 24 hours or so. The one just after 1 this morning was the ip profile being reset I wonder if the others were you or the line dropping?
The profile is now back up to 3500 so if you go into your router and disconnect/reconnect you'll see the speed go up. When did you plug into the test socket, it seems to have helped but obviously we'll have to keep an eye on things.
Jojo
18-10-2010 4:52 PM
You quote...
Hi ggiannandrea
regarding the line dropping or being reset I'm not sure what that means but the router has been plugged in and powered up 24/7 since I obtained it from you on Friday
.I will reboot the router and give it another test for you
regards
Giovanni
