Slow speeds despite running through all checks.
- Slow speeds despite running through all checks.
Re: Slow speeds despite running through all checks.
09-12-2010 2:47 PM
I'm only seeing sync of 2294 at the moment, have you rebooted since your last post?
Jojo
09-12-2010 3:31 PM
09-12-2010 3:36 PM
If you're getting higher sync now then leave it but if you're going to re-sync it's always best to do it during daylight hours.
Jojo
09-12-2010 3:59 PM
09-12-2010 6:49 PM
I tried disconnecting and reconnecting the router and it's the same. Not sure if the person who called me earlier who was responding to a connection problem I logged on the plusnet site has done something but it's mega slow
09-12-2010 7:00 PM
What was said?
And sice when was 18:00 during the daylight. Never reboot after about 2 pm, you will get a slow speed
09-12-2010 8:39 PM
I cannot believe this is correct because I am only on a up to 8mg connection, but it would be nice if it was true!!!
I did ask a few weeks ago why I could not get the full 8mg but this is way over the top
Puddy
10-12-2010 12:47 AM
Just did a reboot and it's synching at 9mb again which is better but I'm getting the same old speeds, that's a shame, I was enjoying my faster internet this morning
Jojo, is my router staying on or can you see regular disconnections? I'll leave it on until Monday now.
10-12-2010 11:10 AM
Firstly, your profile is still 2000 and your line is not banded - but that surprises me looking at the visual below:
Can you explain any of these. Especially the large ares of no connection?
Jojo
10-12-2010 12:53 PM
It seems to have gone a bit haywire on Thursday though, no idea what was causing that, I'm at work from 10am to 6pm so I wasn't doing anything to it, I thought I'd left it on but the connection was horrendous, then upto today where it was so slow I reset it before bed and it synched at 9000 and has been fine since it seems.
It'll definitely get left on from now on though.
10-12-2010 12:59 PM
There's very little noise on the line and when the BT engineer came he fitted the socket, went up the pole outside and rewired it to ensure it was secure and went over to the junction box(which is just across the road) and did that, the line comes straight in through the roof, to the socket(I'm in the top flat) over very little distance and then there's just a microfilter the router connected right by the wall, if it is unstable, what else can cause it?
10-12-2010 1:01 PM
It's looking a lot more steady at the moment and the profile hasn't decreased. I think rather than do anything yet, we should see if today's stability remains and take it from there, just don't reboot.
Jojo
13-12-2010 6:50 PM
Not sure what's causing it to cut out though, will just keep leaving it on, the speeds are fine for what I need for now.
14-12-2010 11:47 AM
Looks like your line is now banded as a result of the disconnections. This is probably what has made your line more stable of late. Do you have a test socket? Are you using any extension cables?
I've updated your fault ticket to show this but could also do with the answers to the 2 previous questions. Also, what router are you using at the moment and do you have another one you can try?
Jojo
14-12-2010 5:12 PM
And finally no, I don't have any extension cables, the socket is less than 3metres from where it gets to the building so there's not much cabling.
