Slow speeds afternoon and evening
- Slow speeds afternoon and evening
17-10-2008 12:07 PM
Regards
Rob
Re: Slow speeds afternoon and evening
17-10-2008 12:40 PM
I've just had a look at your account and can't see anything there that might have caused any issues, so I'd say it's down to congestion at the exchange or failing that the times you are talking about are those when the network is busiest.
17-10-2008 1:12 PM
I think the issue is the number of gold traffic packets being dropped lately at peak times. People may think I have a bugbear about this, but according to your webpage, you aim to have zero gold drops. I can appreciate at peak time this is difficult, but over the last couple of nights I have seem very laggy browsing, speedtester is up and down like a yoyo, not a smooth rise, this always is assopciated with large number of gold traffic being dropped. Also one of the edge routers appears to be offline, is this something to do with the upgrades you are doing, and causing the netowkr to be out of balance. Last time this happened was again when you tried to upgrade an edge router firmware, and had to roll back. Can you provide any explanation as to the excessive numbers of gold traffic being dropped at the moment at peak times. Also I am using the RIN network, that should not be affected by this, and am seeing laggness at peak times here as well, but it could be caused by something completely different.
Edit... My exchange is green, and has been green for ages.
17-10-2008 1:28 PM
Quote Also I am using the RIN network, that should not be affected by this
Hi Penfold,
You're correct - we don't have any control over the RIN network as it's owned by BT so it certainly won't be anything related to the gold drops there. With regard to that, there's been a bit more traffic this week because of patch Tuesday which will account for the majority of the gold drops we've been seeing. Even taking this into account though there haven't been enough drops on the gold protocol to cause any issues.
I'd recommend switching back to our network for a bit to see if your service improves at all - I know Chris was on RIN until last night or so and his Xbox live performace was much improved once he'd moved back to the PN network.
17-10-2008 2:08 PM
Many thanks for checking that all appears okay with my account. My point is that I have a rock solid 4+mb connection at all times but that there has been a noticeable drop in speeds at the times I mentioned only over the last 2 or 3 nights, never before. I presume that congestion and ‘patch Tuesday traffic’ must be about typical. Do you have any thoughts/analysis on what can be causing these problems this week specifically?
Rob
17-10-2008 2:29 PM
Let me know if it doesn't get any better and I'll see if there's anything we can do. What status does your exchange show if you check it at http://usertools.plus.net/exchanges/ ?
17-10-2008 2:34 PM
I have a connection with O2 that has been about 3-5Mbps slower than usual over the last couple of nights, so I reckon it's affecting other ISPs too.
17-10-2008 2:46 PM
ps Exchange Status ' No plans for 21CN'
17-10-2008 2:53 PM
I don't think my explanation is actually that far off the truth, especially coupled with my experience on a different ISP
17-10-2008 3:03 PM
Not with Plusnet then James?
17-10-2008 4:21 PM
B.
17-10-2008 4:23 PM
hope you dont mind me asking but why you with o2 and not pn. i only put my sister on o2 as she is at uni and has a o2 contract fone so was cheaper than a bag of chips for the 8mb product from o2 as she wasnt going to be doing more than genral web surfing I wasnt to botherd if there network didnt perform as well as pn.
There not to bad but i have seen them have alot of dns problems and the broadband member centre is lacking alot of information compared to pn. not forgeting there stupid in house firmware on there routers.
17-10-2008 5:12 PM
It will probably depend on where in the country she is. My congestion yesterday will have been backhaul or exchange based and it's rather hard to tell which!
FWIW, I'm on O2 because I wanted to see what ADSL2+ was like from a curiosity standpoint and should (heaven forbid) Plusnet ever experience connection difficulties, I'm able to update people on the community site. I also have an O2 mobile contract.
Their member centre is appalling compared to Plusnet.
18-10-2008 10:05 AM
19-10-2008 7:13 PM
These days I'm only using the internet for surfing, so I kind of expect it to work well, and fast!! I'm not using P2P, nothing else, other than web browser.
I'd like to hear that there is a problem going on, and one that is being worked on with a solution in very near sight, because I get irritated when I can't surf as fast as I want to. I don't have the patience to raise a ticket or do bt speedtests etc, because I think it is slow externally.
Is superfast broadband coming? one which won't be so congested... Or should I be paying more? I didn't notice this when I was on premier (not that I remember, though my memory is poor). Is it because I switched to broadband your way option 2? Is it meant to be slow each evening? sometimes it goes to about 1MB (kind of worst case) - at good times it's about 6MB - that's quite a drop no?
