Slow speeds - Noisy Line (Still not resolved!!)
- Slow speeds - Noisy Line (Still not resolved!!)
17-06-2010 10:17 PM
Re: Slow speeds - Noisy Line
17-06-2010 10:22 PM
Don't mention broadband
You should also try it from the test socket with a corded phone as this will take your internal wiring out of the equation and also possible noise from the DECT phone
If you can post the stats from your router (noise margin, attenuation and speeds) that will give us a better idea what is happening
17-06-2010 10:26 PM
how do I post my router stats?
17-06-2010 10:29 PM
And welcome to the forums
17-06-2010 10:33 PM
Uptime: 0 days, 0:12:28
DSL Type: G.992.1 annex A
Bandwidth (Up/Down) [kbps/kbps]: 448 / 1,376
Output Power (Up/Down) [dBm]: 11.5 / 16.0
Line Attenuation (Up/Down) [dB]: 31.5 / 55.0
SN Margin (Up/Down) [dB]: 20.0 / 15.0
Vendor ID (Local/Remote): TMMB / ALCB
Loss of Framing (Local/Remote): 119 / 0
Loss of Signal (Local/Remote): 525 / 0
Loss of Link (Remote): 0
Error Seconds (Local/Remote): 450 / 0
FEC Errors (Up/Down): 0 / 37
CRC Errors (Up/Down): 0 / 1
HEC Errors (Up/Down): 0 / 1
17-06-2010 10:33 PM
17-06-2010 10:42 PM
The things which make me assume that are
Noise margin - the default noise margin has been increased from 6dB to 15dB due to instability or massive errors.
The loss of signal - which probably doesn't reset unless the router is rebooted - is still very high for a month
Can you run the BT speedtest and report the results http://community.plus.net/library/broadband/using-the-revised-bt-speedtester/
Did you resync the router about 12 minutes before you took those stats (or disconnected it from the phone line)
Are all items attached to the telephone line filtered - this includes Sky boxes
17-06-2010 10:48 PM
Your right Jim, I think my connection dropped out around the 12 minute mark. It seems to do that fairly often at the moment.
17-06-2010 10:58 PM
17-06-2010 11:01 PM
18-06-2010 8:20 AM
The one bit we really want is the IP Profile speed.
However, if you have a crackly line you need to report that to whoever you pay for your phone rental - and don't say anything about the broadband - you must get them to fix the crackling on the line. Before you do that however I'd recommend you get hold of a second wired phone to double check (in the test socket again) that the noise you can hear is from the line not a problem with your phone.
18-06-2010 2:11 PM
@Bueller.... Bueller.... Bueller.... Bueller.... Bueller.... (sorry couldn't resist) - I've tested the line and there's no immediate faults apparent. Could you do as jelv says above please and test the line with just one wired phone in the master socket, and let us know if the line's still crackly (and also if it's constantly crackly or if it's an intermittent issue)? I'll be able to get you a fault raised if it is still noisy.
(I really hope your username is a reference to the film I'm thinking of or I'll feel really silly :))
18-06-2010 2:14 PM
18-06-2010 5:02 PM
I had a Buell motorcycle, hence Bueller.
I shall check the line again now
18-06-2010 5:06 PM
Download Speed
310 Kbps
0 Kbps 500 Kbps
Max Achievable Speed
Download speedachieved during the test was - 310 Kbps
For your connection, the acceptable range of speeds is 50-500 Kbps.
Additional Information:
Your DSL Connection Rate :448 Kbps(DOWN-STREAM), 448 Kbps(UP-STREAM)
IP Profile for your line is - 350 Kbps
