Slow speed
- Re: Slow speed
Slow speed
27-07-2010 1:42 PM
DSL Connection
Link Information
Uptime: 4 days, 1:46:28
DSL Type: G.992.5 annex A
Bandwidth (Up/Down) [kbps/kbps]: 440 / 8,328
Output Power (Up/Down) [dBm]: 12.5 / 0.0
Line Attenuation (Up/Down) [dB]: 20.0 / 43.5
SN Margin (Up/Down) [dB]: 25.5 / 8.5
Loss of Signal (Local/Remote): 1 / 0
Loss of Link (Remote): 0
Re: Slow speed
27-07-2010 2:07 PM
If from Plusnet can you check with the BT speedtest
Re: Slow speed
27-07-2010 2:23 PM
Download speedachieved during the test was - 4158 Kbps
For your connection, the acceptable range of speedsis 1000-7150 Kbps.
Additional Information:
Your DSL Connection Rate :8328 Kbps(DOWN-STREAM), 440 Kbps(UP-STREAM)
IP Profile for your line is - 6500 Kbps
The throughput of Best Efforts (BE) classes achieved during the test is - 15.38:31.79:52.83 (SBE:NBE:PBE)
These figures represent the ratio while sententiously passing Sub BE, Normal BE and Priority BE marked traffic.
The results of this test will vary depending on the way your ISP has decided to use these traffic classes
Re: Slow speed
27-07-2010 2:25 PM
Re: Slow speed
27-07-2010 2:27 PM
Re: Slow speed
27-07-2010 2:29 PM
Re: Slow speed
27-07-2010 2:41 PM
However I am not sure why the IP profile isn't higher unless you had a slightly lower sync in the last few days
Re: Slow speed
27-07-2010 2:44 PM
Re: Slow speed
27-07-2010 2:48 PM
Re: Slow speed
27-07-2010 2:49 PM
Re: Slow speed
27-07-2010 2:52 PM
