Slow speed on plusnet BB
- Slow speed on plusnet BB
28-02-2013 6:43 PM
Re: Slow speed on plusnet BB
28-02-2013 11:29 PM
DSL Connection
Link Information
Uptime: 0 days, 2:32:33
DSL Type: G.992.5 annex A
Bandwidth (Up/Down) [kbps/kbps]: 752 / 288
Output Power (Up/Down) [dBm]: 12.0 / 17.0
Line Attenuation (Up/Down) [dB]: 18.0 / 30.5
SN Margin (Up/Down) [dB]: 9.0 / 33.0
Vendor ID (Local/Remote): TMMB / TSTC
Loss of Framing (Local/Remote): 2,217 / 0
Loss of Signal (Local/Remote): 274 / 0
Loss of Link (Remote): 0
Error Seconds (Local/Remote): 313 / 0
FEC Errors (Up/Down): 678 / 0
CRC Errors (Up/Down): 678 / 0
HEC Errors (Up/Down): 729,595 / 0
28-02-2013 11:33 PM
It looks as though your line has been banded, this usually happens when your connection has been dropping out (perhaps historically).
I'll take a look at your line for you and see what can be done remotely to restore the service back to normal for you when I get back into the office tomorrow.
28-02-2013 11:40 PM
28-02-2013 11:44 PM
28-02-2013 11:47 PM
28-02-2013 11:49 PM
28-02-2013 11:55 PM
01-03-2013 12:11 AM
01-03-2013 9:56 AM
01-03-2013 10:21 AM
But unless you are on the older Plusnet Essentails Phone package (nothing to do with Essentials Broadband) then you get inclusive evening 7pm-7am and weekend calls upto 60 minutes to UK 01.02.03 & 0845/0870 numbers, why wouldn't you use it? Kids - yes, can't trust them to hang up in the 59th minute and redial or to not call mobile numbers or 09 numbers
But anyway, I can assure you that a corded phone can be a very handy diagnostic tool in helping to analyse a BB fault.
01-03-2013 10:44 AM
DSL Connection
Link Information
Uptime: 0 days, 9:25:45
Bandwidth (Up/Down) [kbps/kbps]: 640 / 288
Line Attenuation (Up/Down) [dB]: 20.5 / 33.5
SN Margin (Up/Down) [dB]: 8.0 / 32.0
Loss of Framing (Local/Remote): 11 / 0
Loss of Signal (Local/Remote): 1 / 0
Error Seconds (Local/Remote): 1 / 0
FEC Errors (Up/Down): 601 / 0
CRC Errors (Up/Down): 601 / 2
HEC Errors (Up/Down): 739,817 / 0
01-03-2013 11:01 AM
01-03-2013 12:30 PM
01-03-2013 12:55 PM
I've placed a SNR reset on your line which has been successful, you should see an increase in speeds in the next 10-15 minutes.
Let me know how you go.
