Slow speed - line resistance
- Re: Slow speed - line resistance
29-04-2013 9:02 PM
30-04-2013 8:36 AM
The estimated repair time for this is tomorrow, so I'll check again then and hopefully this will be rectified. I'll keep you posted.
30-04-2013 11:55 AM
Just out of interest, is this a fault with the exchange part of the line? Sorry to be ignorant, but I'd like to understand.
30-04-2013 1:39 PM
30-04-2013 1:51 PM
Test Results:Unbalanced cable
Again, apologies for being ignorant and thanks for the response
30-04-2013 2:02 PM
I take it you are still connected to the Test socket. Do you have any fixed extension phone sockets?
Edit: minor typo
30-04-2013 2:35 PM
30-04-2013 2:46 PM
Have they asked for someone to be at the property tomorrow (I'm assuming from Chris's post) when the engineer is supposedly fixing the fault?
30-04-2013 2:58 PM
Cheers
30-04-2013 3:18 PM
30-04-2013 4:26 PM
If an appointment had been made in advance, I might have been able to arrange working from home
01-05-2013 9:52 AM
FYI I've just checked the fault and can see a note has been added to show that a fault between the DP and exchange (ie outside of your premises) has been identified and should be worked on today.
Adam
01-05-2013 11:46 AM
Thank you for the update.
Is there any chance of some compensation for this issue? it has been ongoing to and fro with support since our house move in January.
01-05-2013 12:22 PM
01-05-2013 12:48 PM
Just want to say thanks for you guys' support here on the forums, you've been great
