Slow speed - line resistance
Anotherone
Champion
Fixes: 21
Re: Slow speed - line resistance
That's the trouble with this kind of fault, you can never be sure until the line is fixed. The modem/router might be iffy, you'll discover in due course.
chrispurvey
The estimated repair time for this is tomorrow, so I'll check again then and hopefully this will be rectified. I'll keep you posted.
loftybloke
Fantastic, thanks.
Just out of interest, is this a fault with the exchange part of the line? Sorry to be ignorant, but I'd like to understand.
Anotherone
Champion
Fixes: 21
What exactly does it say on the fault ticket? At a guess it's a bad or disconnected joint somewhere between your Master socket and the exchange.
loftybloke
Fault Type:Noise
Test Results:Unbalanced cable
Again, apologies for being ignorant and thanks for the response
Anotherone
Champion
Fixes: 21
It's OK, I don't suppose anyone expects you or anyone else to be a knowledgeable tech!
I take it you are still connected to the Test socket. Do you have any fixed extension phone sockets?
Edit: minor typo
loftybloke
Yep, straight into test socket.  It's the only phone socket in the house (that I've found - we haven't been there long) if that's what you mean?
Anotherone
Champion
Fixes: 21
Can you see the route that the incoming BT line takes into the house, is it overhead or underground? - Just in case there's another socket hidden away somewhere!
Have they asked for someone to be at the property tomorrow (I'm assuming from Chris's post) when the engineer is supposedly fixing the fault?
loftybloke
No request for presence at the property.  I'll definitely check when I get home/in the morning for any obvious points of entry for the phone
Cheers
Anotherone
Champion
Fixes: 21
Will someone be around tomorrow, even if they haven't requested access, you never know, someone may turn up to run a test etc.
loftybloke
No, we both work fulltime.
If an appointment had been made in advance, I might have been able to arrange working from home
adamwalker
Fixes: 221
@loftybloke
FYI I've just checked the fault and can see a note has been added to show that a fault between the DP and exchange (ie outside of your premises) has been identified and should be worked on today.
Adam
 Adam Walker
loftybloke
Hi
Thank you for the update.
Is there any chance of some compensation for this issue? it has been ongoing to and fro with support since our house move in January.
adamwalker
Fixes: 221
We're not compensated by our suppliers for downtime I'm afraid so we're not able to do that I'm afraid.  I totally appreciate you've mentioned there may have been problems since January but it looks like this hasn't been broached with us since between a fault raised towards the end of February and 25/4/13.
 Adam Walker
loftybloke
That's fine, it's always worth asking though I suppose Smiley
Just want to say thanks for you guys' support here on the forums, you've been great
